ZEN Rang: Administrateur
Nombre de messages: 31932 Date d'inscription: 05/05/2005
 | Sujet: PANERAI Sam 24 Fév - 17:08 | |
| PANERAI RADIOMIR 1936  | Citation: | Technical specification
Case In three parts, diameter 47 mm, in steel with polished finish, with removable wire link strap attachments fixed to the case by small screws (Officine Panerai patent). Personalised screw-down winding crown. Plexiglas® crystal 2 mm thick
Bezel Steel with polished finish
Back Steel, screw, with sapphire crystal window
Water-resistance To 30 metres
Movement Hand-wound mechanical, Panerai calibre OP X, 16½ lignes, 17 jewels, 21,600 vibrations/hour, Glucydur®, balance, Nivarox® I balance spring, Incabloc® anti-shock device, “swan neck” regulation of the active length of the balance spring. Power reserve of 56 hours, Côtes de Genève decoration, blued screws
Functions Hours and minutes
Dial Black with luminous triangular index, baton hour markers, Roman and Arabic numerals
Strap In natural hand-sewn leather, the inner part made of hypoallergenic material, personalised steel buckle sewn to the strap
Reference PAM00249
Production Series limited to 1936 units
Retail price 4,800 €
Distributed from December 2006
Other versions Case in platinum (reference PAM00262), strap in hand-sewn leather, personalised white gold buckle sewn to the strap. Unique edition of 99 units (29,000 €) |
PANERAI RADIOMIR 1938
Sapphire crystal 1.9 mm thick with anti-reflective treatment
Back Steel, screw
Water-resistance To 100 metres
Dial Brown, “sandwich” type, with luminous baton hour markers and Arabic numerals
Reference PAM00232
Production Series limited to 1938 units
Retail price 4,400 €
Officine Panerai is not the owner of the trademarks Incabloc®, Glucydur® and Nivarox® |
PANERAI LUMINOR GMT NORTH POLE
Case In three parts, diameter 44 mm, in steel with supplementary anti-magnetic case of soft iron. Device protecting the winding crown (Trade Mark), sapphire crystal 3 mm thick with anti-reflective treatment, magnifying lens for the date applied internally to the crystal at 3 o’clock
Bezel In steel, with the 4 letters of the cardinal points applied Caseback Screw back in steel with a diagram showing the polar ice cap and the course of the North Pole Winter Expedition, accompanied by the signatures of Mike Horn and Borge Ousland
Water-resistance To 300 metres
Movement Automatic mechanical, Panerai calibre OP VIII, 13¼ lignes, 21 jewels. Glucydur® balance with three arms, operating frequency 28,800 vibrations/hour. Incabloc® anti-shock device. Power reserve of 42 hours. Chronometer Certificate (COSC)
Functions Hours, minutes and seconds, date, second time zone
Dial Blue with luminous numerals and markers, small seconds at 9 o’clock, date window at 3 o’clock, second time zone indication on the outer edge
Strap Water-resistant Velcro
Reference PAM00252
Officine Panerai is not the owner of the trademarks Incabloc®.and Glucydur®. |
Panerai Luminor 1950 8 Days GMT
| Citation: | Panerai Luminor 1950 8 Days GMT Steel case and Calibre P.2002 for the Manufacture collection
After the Radiomir 8 Days GMT of 2005, a limited edition of which marked the premiere of the Calibre P.2002, created in the Panerai manufacture in Neuchâtel, the Luminor 1950 8 Days GMT with the same movement is inaugurating the Manufacture collection, a family of watches which uses movements 100% made in Panerai.
The aesthetic of the Luminor 1950 case is celebrated once again in a range inspired by Panerai’s military past, but with an updated, sharper design with precise detailing. With a diameter of 44 millimetres, the steel case has the device which identifies Panerai in the watchmaking field, that is, the patented bridge protecting the winding crown (the inscription RE. T.M. on the bridge confirms its exclusiveness) which ensures the perfect water-resistance of the watch.
The Calibre P.2002 interprets the complications traditionally expressed by Panerai through the application of its resources of craftsmanship and complete technical understanding. The power reserve of 8 days, tested by Panerai at the end of the 1940s, has been repeated in the Panerai movement by using an assembly consisting of three spring barrels. To achieve accurate setting of the hands and synchronisation with the reference time signal, the seconds hand jumps to zero as a result of the zero reset device, a sophisticated zeroing system which at the same time instantly stops the balance wheel. Avant-garde techniques are employed in the construction of the movement. This is hand-wound and consists of 245 components, with a free-spring balance and no conventional regulator. This means that very precise regulation can be carried out by adjusting the screws directly on the balance wheel itself.
The Luminor 1950 8 Days GMT’s black cushion dial (formed of two superimposed plates, the upper one being perforated and the lower one covered with luminous material) has a little calendar window at 3 o’clock, symmetrically complemented by the traditional continuous seconds dial. The power reserve indication, employing a triangular index which moves across a graduated linear scale, is at 6 o’clock, while the arrow-pointed centre hand of the second time zone is partnered by the day/night subdivision, visible through the circular aperture at 9 o’clock, which through its different colours enables the hours before and after midday to be distinguished.
PANERAI LUMINOR 1950 8 DAYS GMT
Case : in three parts, diameter 44 mm, in steel with brushed finish, device protecting the winding crown (Trade Mark), sapphire crystal 2 mm thick with anti-reflective treatment.
Bezel: steel with polished finish.
Caseback: see-through, secured with screws, with sapphire crystal window.
Water-resistance : to 100 metres.
Movement: hand-wound mechanical, Panerai calibre P.2002, completely manufactured by Panerai, 13¾ lignes, 21 jewels, Glucydur® balance, Incabloc® anti-shock device, operating frequency 28,800 vibrations/hour. Power reserve 8 days, 3 spring barrels in series (Officine Panerai patent).
Functions: hours, minutes and seconds, date, 12-hour second time zone, day/night indication, power reserve indication.
Dial: black, with luminous baton markers and Arabic numerals at 6 and 12 o’clock, small seconds at 9 o’clock, date at 3 o’clock, second time zone indication by centre hand and small dial divided into 24 hours at 9 o’clock with day/night indication, linear power reserve indication at 6 o’clock.
Strap: leather with brushed large size personalised buckle in steel. Supplied with steel screwdriver and spare strap in rubber.
Reference: PAM00233
Price to the public: € 8,900
Production: 1,500 units for 2006
Distributed from: September 2006
Officine Panerai is not the owner of the trademarks Glucydur® and Incabloc® |
