| | Auteur | Message |
ZEN Rang: Administrateur
Nombre de messages: 31932 Date d'inscription: 05/05/2005
 | Sujet: ZENITH Ven 23 Fév - 21:23 | |
| ZENITH Collection DEFY 2007 DEFY XTREM CHRONO  | Citation: | Caliber El Primero 4035 SX Automatic chronograph movement with tourbillon 15 1/2``` caliber. Diameter : 37.5 mm. Height : 7.55 mm. 332 components. Train wheel bridge, chronograph and lower cage bridges are in shock-absorbing Zenithium Z+ Incabloc® anti-shock device 36’000 vibrations per hour Power reserve over 50 hours 35 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Heavy Metal oscillating weight with carbon fiber inserts
Functions Hour and minutes in the center Date indication positioned around the carriage Tourbillon: • The carriage is positioned at 11 o’clock • The carriage makes 1 turn per minute Central seconds-hand 30-minute counter at 3 o’clock 12-hour counter at 6 o’clock
Case Black Titanium case. Diameter: 46.5 mm Black Titanium screw-in push-buttons with carbon fiber guilloché patterns Black Titanium screw-in crown with specific protecting device Graduated unidirectional rotating bezel in black Titanium with Titanium indexes Helium valve at 10 o’clock Black Titanium screw-in case back Water-resistance up to 1’000 meters
Dial Multi-layered see-through structure composed of shock-resistant transparent Hesalite glass, Carbon fiber layer and silver-coated dial flange Propeller-shaped upper tourbillon bridge which unveils the regulating organ of the 4035 SX caliber
Crystal Sapphire glass, 3.8 mm thick, with anti-reflective coating on both sides Hands Rhodium-plated luminous hands with red Superluminova inserts Hour & minute “skeleton” rhodium hands
Bracelet High-temperature resistant bracelet in brushed stainless steel. Kevlar® lateral inserts and central links made of carbon fiber & composite alloys
Straps Also available on black genuine rubber strap and black alligator leather strap
Buckle Brushed stainless steel triple folded clasp for the bracelet Brushed stainless steel tongue buckle for leather & rubber straps |
| Citation: | Caliber El Primero 4035 SX Automatic chronograph movement with tourbillon. New gold plated auxiliary plate 16 1/2``` caliber. Diameter : 37.5 mm. Height : 7.55 mm. 325 components. 35 jewels Train wheel bridge, chronograph and cage bridges are in shock-absorbing Zenithium Z+ Incabloc® anti-shock device 36’000 vibrations per hour Power reserve over 50 hours Measures short time intervals to a 10th of a second Automatic winding in both directions. Central rotor on ball bearings Heavy Metal oscillating weight
Case Black Titanium case. Diameter: 46.5 mm Screw-in guilloche push-pieces in rose gold and black titanium Black Titanium screw-in crown with black titanium shock protector Graduated unidirectional rotating bezel in black Titanium with rose gold screw heads & cone-shaped indexes Helium valve at 10 o’clock Black Titanium screw-in case back with carbon fiber guilloché pattern Water-resistance up to 1’000 meters
Dial Multi-layered see-through structure composed of shock-resistant transparent Hesalite glass, Carbon fiber layer and nitrocellulosed nickel-coated dial plate. Propeller-shaped tourbillon bridge in solid rose gold which unveils the regulating organ of the 4035 SX caliber
Crystal Highly scratch resistant sapphire glass, 3.8 mm thick, with anti-reflective coating on both sides Hands All hands in Rose gold with brown Superluminova inserts Hour & minute “skeleton” rose gold hands, wheel-shaped hands for the chronograph counters
Bracelet High-temperature resistant bracelet in gold & black titanium: Solid titanium structure reinforced by Kevlar® lateral inserts, 21 central links in rose gold, with solid black titanium triple folded clasp
Also available on black genuine rubber strap and black leather strap, with rose gold tongue buckle |
DEFY CLASSIC
| Citation: | Caliber El Primero 4021 SC Automatic chronograph movement with harmonic plate 13``` caliber. Diameter 30 mm. Height : 7.75 mm. 248 components. Balance bridge in shock-absorbing Zenithium Z+ Incabloc® anti-shock device 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Full tungsten oscillating weight with guilloché pattern
Functions Hours and minutes in the center Small seconds-hand at 9 o’clock with a 3-branched hand Power reserve indicator from hour axis Central seconds-hand 30-minute counter at 3 o’clock
Case Brushed stainless steel case with rose gold bezel. 2 sizes available: Diameter: 46.5 mm & 43 mm Screw-in push buttons with specific guilloche pattern Screw-in crown engraved with ZENITH star Graduated unidirectional rotating bezel, with screw-heads & satin-finished cone-shaped indexes in rose gold Transparent sapphire case back Screw-in case back Water-resistance up to 300 meters
Dial Silver or black fully guilloché dial Opening at 10 o’clock revealing heart of 4021 SC El Primero caliber Rose gold applied indexes & numerals
Crystal Sapphire glass, 3 mm thick, with anti-reflective coating on both sides
Hands Rose gold faceted luminous hands with white Superluminova inserts
Straps Black or brown handmade alligator leather strap Black or brown rubber strap Bracelet Brushed high-density stainless steel & rose gold bracelet
Buckle Brushed stainless steel triple-folded clasp for the bracelet Brushed stainless steel tongue buckle for rubber & leather straps |
| Citation: | Caliber El Primero 4000 SC Automatic chronograph movement 13 ¼’’’ caliber. Diameter 30 mm. Height : 6.50 mm. 278 components. Balance bridge in shock-absorbing Zenithium Z+ Incabloc® anti-shock device 36’000 vibrations per hour Power reserve over 50 hours 31 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Full Tungsten oscillating weight with guilloché pattern
Functions Hours and minutes in the center Small seconds counter at 9 o’clock Date at 4 ½ o’clock Central seconds-hand for the chronograph 30-minute counter at 3 o’clock 12-hour counter at 6 o’clock
Case Brushed stainless steel case Case diameter : 46.5 mm (XT) or 43 mm (T) Screw-in push buttons with specific guilloche pattern Screw-in crown engraved with ZENITH star Graduated unidirectional rotating bezel, with stainless steel decorative screw-heads & satin-finished cone-shaped indexes Transparent sapphire case back Screw-in case back Water-resistance up to 300 meters
Dial Silver or black fully guilloché dial Applied rhodium numerals and indexes
Crystal Sapphire glass, 3 mm thick, with anti-reflective coating on both sides Magnifying lens over the date window at 4 ½ o’clock
Straps Black or brown handmade alligator leather strap Black or brown rubber strap Bracelet Brushed high-density stainless steel bracelet
Buckle Brushed stainless steel tongue buckle for rubber & leather straps Brushed stainless steel triple-folded clasp for the bracelet |
DEFY XTREM ELITE
| Citation: | Caliber Elite 685 SX Extra-thin automatic movement New gold plated auxiliary plate 11 ½’’’ caliber. Diameter 25.6 mm. Height : 4.48 mm. 179 components. Balance, automatic train and train wheel bridges in shock-absorbing Zenithium Z+ Incabloc® anti-shock device 28’800 vibrations per hour Power reserve over 50 hours 38 jewels Automatic winding in both directions Central rotor on ball bearings Heavy Metal oscillating weight with carbon fiber inserts
Functions Hours and minutes in the center Small seconds counter at 9 o’clock Date at 4 ½ o’clock Power reserve indicator at 1 o’clock
Case Black Titanium case. Diameter: 43 mm Black Titanium screw-in crown with shock protecting device Graduated unidirectional rotating bezel in Black Titanium, with rose gold screw heads & cone-shaped indexes Helium valve at 10 o’clock Black Titanium screw-in case back Water-resistance up to 1’000 meters
Crystal Highly scratch-resistant sapphire glass, 3.8 mm thick, with anti-reflective coating on both sides. Magnifying lens over the date window at 4 ½ o’clock
Hands All hands in rose gold with brown Superluminova inserts Hour & minute “skeleton” hands in rose gold 3 gold plated wheel-shaped hands for second & chronograph counters
46,5 mm de diamètre pour les chronos et 43 mm pour la version Elite.[/center]
http://www.zenith-watches.com/scripts/getpage.asp?pageid=5_4&langid=1&myurl=/img/4_news-events/4_4_corner/pics/&newsid=49&item=0&mycount=16 _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
 | Sujet: ZENITH Baby Doll Lun 26 Fév - 14:07 | |
| ZENITH BABY DOLL   | Citation: | Caliber NEW Elite 68 Automatic movement 11 1/2``` caliber. Diameter: 25.6 mm. Height: 3.81 mm. 127 components. 28’800 vibrations per hour Power reserve over 50 hours 27 jewels Automatic winding in both directions Central rotor on ball bearings White gold oscillating weight, decorated with stamped ZENITH numerals and stars
Case White gold case personalized with engraved ZENITH Stars 21 white diamonds (0.3-ct) set on the bezel Diameter: 32 mm Diameter opening: 22 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back engraved with ZENITH stars Water-resistance up to 100 meters
Dial Silvered mother of pearl dial set with 6 diamonds 9 diamonds (0.16-ct) adorns the dial as indexes Starfish opened dial at 10 o’clock showing the heart of Elite
Hands White gold leaves Small second hand symbolized with a Starfish
Strap White galuchat strap
Buckle White gold simple buckle with the ZENITH Star on the cap |
| Citation: | Caliber El Primero 4021 Automatic chronograph movement 13 1/4’’’ caliber. Diameter: 30 mm. Height: 7,75 mm. 248 components 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings 22-cts yellow or rose gold oscillating weight, decorated with stamped ZENITH numerals and stars
Functions Hours and minutes in the center Small seconds-hand at 9 o’clock Power reserve indicator from hour axis Central seconds-hand 30-minute counter at 3 o’clock
Case 18-cts yellow or rose gold case with personalized bezel, engraved with ZENITH Stars and graduation 21 white diamonds (0.3-ct) set on the bezel Diameter: 37.5 mm Diameter opening: 28 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back with engraved ZENITH stars Water-resistance up to 100 meters
Dial Silvered mother of pearl dial set with 6 diamonds 9 large pearls adorns the dial as indexes Starfish opened dial at 10 o’clock showing the heart of El Primero Power reserve graduation symbolized with starfishes under hour axis
Hands Yellow or rose gold leaves Small second hand symbolized with a Starfish Power reserve indication symbolized with a shooting star from hour axis
Strap Beige or ZENITH brown galuchat strap
Buckle Yellow or rose gold triple folding buckle stamped with the ZENITH star on the cap |
| Citation: | Caliber NEW Elite 68 Automatic movement 11 1/2``` caliber. Diameter: 25.6 mm. Height: 3.81 mm. 127 components. 28’800 vibrations per hour Power reserve over 50 hours 27 jewels Automatic winding in both directions Central rotor on ball bearings 22-cts yellow or rose gold oscillating weight, decorated with stamped ZENITH numerals and stars
Case 18-cts yellow or rose gold case personalized with engraved ZENITH Stars 21 white diamonds (0.3-ct) set on the bezel Diameter: 32 mm Diameter opening: 22 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back engraved with ZENITH stars Water-resistance up to 100 meters
Dial Silvered mother of pearl dial set with 6 diamonds 9 large pearls adorns the dial as indexes Starfish opened dial at 10 o’clock showing the heart of Elite
Hands Yellow or rose leaves Small second hand symbolized with a Starfish
Buckle 18-cts yellow or rose gold simple buckle with the ZENITH Star on the cap |
Star Open Sea Colors
| Citation: | ELITE
Caliber NEW Elite 68 Automatic movement 11 1/2``` caliber. Diameter: 25.6 mm. Height : 3.81 mm. 127 components. 28’800 vibrations per hour Power reserve over 50 hours 27 jewels Automatic winding in both directions Central rotor on ball bearings Heavy metal or 22-cts yellow or rose gold oscillating weight, decorated with stamped ZENITH numerals and stars
Case Stainless steel or 18-cts yellow or rose gold case personalized with engraved ZENITH Stars Available with 21 white diamonds (0.2-ct) set on the bezel Diameter: 32 mm Diameter opening: 22 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back engraved with ZENITH stars Water-resistance up to 100 meters
Dial White, black, jade-green, coral-red, turquoise, pink or silvered dial with dancing numerals and Zenith Stars engraved in mother of pearl Powdered dancing numerals and Starfishes as indexes Starfish opened dial at 10 o’clock showing the heart of Elite A white, black or pink pearl, or a turquoise, a jade or a piece of non-protected coral adorns the dial at 3 o’clock
Hands Rhodium, yellow or rose leaves Small second hand symbolized with a colored Starfish
Strap White, black, jade-green, coral-red, turquoise, pink, beige or ZENITH brown galuchat strap
Buckle Stainless steel, 18-cts yellow or rose gold simple buckle with the ZENITH Star on the cap |
| Citation: | CHRONO
Caliber El Primero 4021 Automatic chronograph movement 13 1/4’’’ caliber. Diameter : 30 mm. Height : 7,75 mm. 248 components 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Heavy metal or 22-cts yellow or rose gold oscillating weight, decorated with stamped ZENITH numerals and stars
Case Stainless steel or 18-cts yellow or rose gold case with personalized bezel, engraved with ZENITH Stars and graduation Available with 21 white diamonds (0.3-ct) set on the bezel Diameter: 37.5 mm Diameter opening: 28 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back with engraved ZENITH stars Water-resistance up to 100 meters
Dial White, pink, black, turquoise, coral-red, jade-green or silvered dial with dancing numerals and Zenith Stars engraved in mother of pearl Powdered dancing numerals and Starfishes as indexes Starfish opened dial at 10 o’clock showing the heart of El Primero Power reserve graduation symbolized with starfishes under hour axis A white, black or pink pearl, or a turquoise, a jade or a piece of non-protected coral adorns the dial at 3 o’clock
Hands Rhodium, yellow or rose gold leaves Small second hand symbolized with a colored Starfish Power reserve indication symbolized with a shooting star from hour axis
Strap White, pink, black, turquoise, coral-red, jade-green, beige or ZENITH brown galuchat strap
Buckle Stainless steel, 18-cts yellow or rose gold triple folding buckle stamped with the ZENITH star on the cap |
 | Sujet: ZENITH Nouveautés Class Open 2007 Mer 18 Avr - 7:58 | |
| ZENITH CLASS 2007 | Citation: | Caliber El Primero 4037 Automatic chronograph movement with grande date 13``` caliber. Diameter : 30.50 mm. Height : 9.05 mm. 351 components. 36’000 vibrations per hour Power reserve over 50 hours 43 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings 22-carat gold or heavy metal oscillating weight with “Grain d’Orge” guilloché pattern
Functions Hours and minutes in the center Small seconds-hand at 9 o’clock Chronograph: • Center seconds-hand • 30-minute counter at 3 o’clock Power Reserve indicator in the center Grande Date over 2 o’clock with instantaneous double jump 24 Time-zone system with day/night indicator
Case Rose gold or Stainless Steel case Stainless Steel ZENITH push buttons and crowns Diameter : 46 mm / Diameter opening : 38 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back Water-resistance up to 50 meters
Dial Silvered “Grain d’Orge” guilloché dial. Open dial at 10 o’clock showing the heart of El primero 4037 Caliber Hand-mounted applique arabic numerals and indexes
Hands Faceted hands in rose gold or ruthenium
Strap Integrated handmade black alligator leather strap lined with silky Alzavel calfskin
Buckle Rose Gold or Stainless Steel triple folded buckle with ZENITH star on the cap
Caliber El Primero 4035 Automatic chronograph movement with tourbillon 16 1/2``` caliber. Diameter : 37.5 mm. Height : 7.55 mm. 25 jewels. 325 components. 36’000 vibrations per hour Power reserve over 50 hours 35 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings 22-carat gold oscillating weight with “Grain d’Orge” or “Côtes de Genève” guilloche pattern
Functions Hour and minutes in the center Tourbillon: • The carriage is positioned at 11 o’clock • The carriage makes 1 turn per minute Chronograph: • Center seconds-hand • 30-minute counter at 3 o’clock • 12-hour counter at 6 o’clock Date indication positioned around the carriage
Case 18-carat rose or white gold case, push-buttons and crown Diameter : 45 mm Diameter opening : 36.5 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back Water-resistance up to 50 meters
Dial Solid gold dial Deep black or silver with handmade “Grain d’orge” guilloché pattern All applied indexes and counters in solid gold
Hands 18-carat rose or white gold faceted hands
Strap Handmade black alligator leather strap lined with silky Alzavel calfskin
Buckle 18-carat rose or white gold Grande Class triple folding buckle stamped with ZENITH star on the cap
Caliber El Primero 4021 J3 Automatic chronograph movement 13``` caliber. Diameter 30 mm. Height : 7.75 mm. 248 components. 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Heavy metal oscillating weight with “Côtes de Genève” guilloché pattern
Functions Hours and minutes in the center Small seconds-hand at 9 o’clock with a 3-branched hand Chronograph: • Centre seconds-hand • 30-minute counter at 3 o’clock Power reserve indicator from hour axis
Case Black Titanium case Black Titanium push-buttons and crown Diameter : 44 mm / Diameter opening : 35 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back Water-resistance up to 50 meters
Dial Skeleton Dial inspired by a car wheel rim Open at 10 o’clock & showing the heart of 4021 J3 El Primero caliber Transferred numerals, applied indexes and ZENITH star
Hands Rhodium faceted hands 18-carat rose gold power-reserve hand
Strap Handmade 3K Carbon fiber integrated strap Also available on black rubber strap
Buckle Black Titanium triple folded buckle with ZENITH Star on the cap
Caliber El Primero 4021H Automatic chronograph movement 13``` caliber. Diameter 30 mm. Height : 7.75 mm. 248 components. 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings Heavy metal oscillating weight with “Côtes de Genève” or “Grain d’Orge” guilloché pattern
Functions Hours and minutes in the center Small seconds-hand at 9 o’clock with a 3-branched hand Chronograph: • Central seconds-hand • 30-minute counter at 3 o’clock Power reserve indicator from hour axis
Case Stainless steel case with satin-finish horns Stainless steel ZENITH push buttons and crown Diameter : 40 mm / Diameter opening : 32.5 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back Water-resistance up to 50 meters
Dial Open dial at 10 o’clock showing the heart of El Primero White, black, grey plain dial or brown guilloche dial Rhodium hand-mounted applique arabic numerals
Hands Rhodium faceted hands 18-carat rose gold power reserve hand
Strap Handmade white, black or brown alligator leather strap lined with silky Alzavel calfskin
Buckle Stainless steel Class triple folded buckle stamped with ZENITH star on the cap
ZENITH BROWN
Caliber El Primero 4021H Automatic chronograph movement 13``` caliber. Diameter 30 mm. Height : 7.75 mm. 248 components. 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings 22-carat gold or metal oscillating weight with “Grain d’Orge” guilloche pattern
Case 18-carat rose gold or stainless steel case with satin-finish horns 18-carat rose gold or stainless steel ZENITH push buttons and crown Grande Class Open: Diameter : 44 mm / Diameter opening : 36 mm Class Open: Diameter : 40 mm / Diameter opening : 32.5 mm
Dial ZENITH brown dial with “Grain d’Orge” guilloché pattern Open dial at 10 o’clock showing the heart of El Primero Rhodium hand-mounted applique arabic numerals
Strap Handmade brown alligator leather strap lined with silky Alzavel calfskin
Buckle 18-carat rose gold or stainless steel Class triple folded buckle stamped with ZENITH star on the cap |
 | Sujet: ZENITH Grande Chronomaster El Primero Open Venice Mer 11 Juil - 15:54 | |
| Grande Chronomaster El Primero Open Venice  | Citation: | Caliber El Primero 4021 Automatic chronograph movement 13``` caliber. Diameter 30.50 mm. Height : 7.75 mm. 248 components. 36’000 vibrations per hour Power reserve over 50 hours 39 jewels Measures short time intervals to a 10th of a second Automatic winding in both directions Central rotor on ball bearings 22-carat rose gold oscillating weight
Case 18-carat rose gold case 18-carat rose gold ZENITH push buttons and crown Diameter : 45 mm / Diameter opening : 35 mm Curved sapphire glass with anti-reflection treatment on both sides Transparent sapphire case back Water-resistance up to 30 meters
Dial Solid 18-carat gold dial with “sundial” guilloché pattern Open dial at 10 o’clock showing the heart of El Primero adorned with handmade rose gold “Venice Lion” strand. 18-carat rose gold hand-mounted applique arabic numerals & indexes
Hands 18-carat rose gold faceted hands Power reserve in black varnish
Buckle 18-carat rose gold ChronoMaster triple folding buckle
LIMITED AND NUMBERED EDITIONS : 100 PIECES ONLY |
| Page 1 sur 1 |
| | Permission de ce forum: | Vous ne pouvez pas répondre aux sujets dans ce forum
