MARQUE : Ocen7
MODELE : LM-7 Ploprof
ANNEE : 2008
Etat général : 2007
Comme neuve. Set complet, boite, surboite, bouton supplémentaire, papiers etc...
Plus de photos sur demande.
Prix = 650 euros + port.
Contact : 06 82 23 38 76
Description issue du site du fabricant :
Face it - dive watches are cool, and the
OCEAN7 LM-7 is the coolest of them all! Wear a dive watch and you can go deep, face hostile creatures, disasterous waves, and miserable weather. Return home, change into a tux, and enjoy your evening with the LM-7 strapped to your wrist.
The LM-7 Dive Watch is history on your wrist. Taking its inspiration from dive watches of the past worn by well known explorers and adventurers, the LM-7 is a pleasure to wear and enjoy.
Both steel and red anodized aluminum bezel release pushbuttons are included. The steel button is installed when the watch ships. Buttons are changed by hand simply by unscrewing the old button and screwing on the new button.
# Brushed Steel Case
# Swiss Automatic Movement
# Diameter - 55mm x 42 mm
# Height - 17mm
# Swiss Super Luminova C3
# Flat Sapphire Crystal with Inside AR Coating
# PU Rubber Sport Strap
# Water Resistance - 1000m/3300ft
# 24mm Lug Spacing
# Screw Down Crown with Etched O7 Logo
# 60 click turning Bezel with Locking Pushbutton
# Weight - 145 grams
# Luminous Sapphire Bezel Insert
# Includes Red Anodized and Brushed Aluminum Bezel Lock Pushbuttons
# Black PU PloProf strap
