| Avant première OMEGA Casino Royale James Bond | |
ZEN Rang: Administrateur
Nombre de messages : 57513 Date d'inscription : 05/05/2005
 | Sujet: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:02 | |
|    - Citation :
- Even whilst relaxing on the beach, only the best is good enough for James Bond, an ethos perfectly reflected in his choice of diving partner. The Seamaster Planet Ocean ‘Casino Royale’ is a potent combination of technical complexity and aesthetic elegance.
The Planet Ocean model is identified by its distinctive bezel, which recalls the original Seamaster 300 metre models, albeit with a choice between classic and highly contemporary interpretations of this historical theme. Meticulous attention to detail resulted in a slightly different bezel design with a model taking on a resolutely sporty look. The unidirectional rotating bezel has minute graduations for the first fifteen minutes, numbers for the subsequent ten-minute sectors and a luminous triangular marker at 12 o’clock. Other features indicating that this is a professional divers’ watch are the watertight screw-in crown, a screw-in case back and the helium escape valve (located at 10 o’clock and embossed with “He”). The Seamaster Planet Ocean is water resistant to 600 metres (2000 feet). The matt black dial also offers excellent clarity, thanks to applied luminous hour markers and Arabic numerals at 12, 6 and 9 o’clock, with date window at 3 o’clock. The facetted arrowhead hour and minute hands also have luminous SuperLuminova inserts, and a luminous arrowhead seconds hand with orange tip offers ultimate visibility down to the last second. Beneath the surface is Omega’s calibre 2500 Co-Axial Escapement movement, which is a COSC-certified chronometer and has a power reserve of 48 hours. The Seamaster Planet Ocean “Casino Royale” is available with a 45.5 mm diameter case and a black rubber strap. This Limited Edition has exclusive features: the central second hand bears the “007” gun logo in orange, that recalls the code name of the famous MI6 secret agent. The stainless-steel case back is embossed with the “Casino Royale” logo as well as the series number of each Limited Edition watch. Limited to 5’007 pieces, the Seamaster Planet Ocean “Casino Royale” will be a perfect collector’s item for all James Bond aficionados. Source Omega _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:07 | |
| Il y a un truc que je ne comprends pas : si on est agent secret, on porte pas une montre avec son matricule dessus non ? Où alors, les méchants sont vraiment bêtes... |
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:14 | |
cedric Animateur
Nombre de messages : 942 Age : 43 Localisation : Grenoble Date d'inscription : 07/07/2005
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:24 | |
| - @foversta a écrit:
Où alors, les méchants sont vraiment bêtes... En même temps, dans James Bond, les méchants sont pas toujours des flêches, ils passent leur temps à expliquer leurs plans au lieu de lui mettre une balle dans la tête  |
Dynamo Membre référent
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:25 | |
| Dommage pour une série spéciale avec simplement une aiguilles des secondes différente. Alors qu'ils avaient puisé dans leurs histoires : une PO avec une lunette avec le marquage de toute les minutes et des aiguilles gladiator-sword comme sur la SM 300 vintage. Dynamo |
tataye80 Membre Actif
Nombre de messages : 101 Age : 40 Localisation : Orléans Date d'inscription : 15/03/2006
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 18:34 | |
| Oui et en plus dans James Bond le personnage se présente toujours avec son vrai nom, depuis le temps, les vilains devrait savoir qui il est !!!! |
kaltan Pilier du forum
Nombre de messages : 1750 Localisation : Bordeaux Date d'inscription : 25/12/2005
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 20:33 | |
| - @tataye80 a écrit:
- Oui et en plus dans James Bond le personnage se présente toujours avec son vrai nom, depuis le temps, les vilains devrait savoir qui il est !!!!
Le vilain il va pas au cinéma... |
clint Membre super actif
Nombre de messages : 460 Localisation : genf Date d'inscription : 09/03/2006
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 21:28 | |
| On l'as pas vu l'année dernière celle la ?  En tout cas, cette pauvre aiguille... je m'y ferai pas ! Et un fond transparent ça serai pas mieux que ce "casino royale", hein ?  |
mal.PIFPAF Membre très actif
Nombre de messages : 184 Age : 42 Date d'inscription : 22/10/2006
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 21:35 | |
| - Citation :
En même temps, dans James Bond, les méchants sont pas toujours des flêches, ils passent leur temps à expliquer leurs plans au lieu de lui mettre une balle dans la tête Mr. Green A lire le passage dans The Watchmen ou ozymandias parle à Rorschach!! Pourquoi ils n'ont pas fait la version avec le sublime cadran orange? |
Jeserlecter Permanent passionné
Nombre de messages : 2176 Date d'inscription : 27/09/2006
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 22:23 | |
| Et puis quand les second sont entre 12 et 6 coté date, le 007 est a l'envers  |
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Mer 15 Nov 2006 - 23:02 | |
| - @mal.PIFPAF a écrit:
En même temps, dans James Bond, les méchants sont pas toujours des flêches, ils passent leur temps à expliquer leurs plans au lieu de lui mettre une balle dans la tête Mr. Green Mr Green le papa d'Eva Green l'epoux de Marlène Jobert . Dynamo |
Seb Membre super actif
Nombre de messages : 321 Age : 43 Localisation : Saïgon Date d'inscription : 15/05/2006
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Jeu 16 Nov 2006 - 1:55 | |
| personnellement, je trouve un peu ridicule d'avoir deux montres officielles pour le film.Pourquoi pas toute la gamme tant que l'on y est ? !!Puis, on rajouterait une petite aiguille sur l'ensemble de celle-ci , ce qui permettait d'avoir une multitude de séries limitées, un peu plus chère. Par ailleurs, je n'accroche pas des masses au bracelet caoutchouc et effectivement cette aiguille n'est pas terrible.
Comme beaucoup ici, je pense qu'Omega se perd dans un marketing (au moins pour la partie Promotion) un peu brouillon et finalement pas très cohérent . Une remise en question autour d'une bonne réflexion sur des nouvelles orientations à prendre leur ferait du bien.
Seb |
 | Sujet: Re: Avant première OMEGA Casino Royale James Bond Jeu 16 Nov 2006 - 12:55 | |
