 quelle pile pour une électro mécanique Hermes?
5 participants
pol
Nombre de messages : 134
quelle pile pour une électro mécanique Hermes? Empty
MessageSujet: quelle pile pour une électro mécanique Hermes?   quelle pile pour une électro mécanique Hermes? EmptyMar 10 Mar 2009 - 20:49
bonjour a tous,
Je viens de récupérer une montre électro mécanique Hermes.
le mouvement est un ESA y2 9154.
la pile dedans est marquée watch 343.
ma question est: la pile est t elle trouvable aujourd hui.
pmk
pmk
Nombre de messages : 5033
MessageSujet: Re: quelle pile pour une électro mécanique Hermes?   quelle pile pour une électro mécanique Hermes? EmptyMar 10 Mar 2009 - 21:46
Avec google, j'ai trouve ça :
344 (SR1136SW)
Type: Silver Oxide. Voltage: 1.55V.
Diameter: 11.6 mm. Height: 3.6 mm.
Price: £1.70 each. £1.50 each if you buy two or more. P&P included.
Also known as: D344, V344, 242, SR1136SW, SR42, SR42L, 529, RW36, S10, 1133SO.
A suitable replacement for the mercury: 343, MR42, MR1136, 509, Bulova 218, Timex B, Citizen 280-05, NP343, HG11, M08, 1154M.
Comments:
The 344 or SR1136SW is a popular silver-oxide cell that are commonly used in watches. The 344 or SR1136SW has a shelf life of 6 + years, so why not buy two or more. Take advantage of our reduced price and make sure you are not left without a watch next time your battery runs out.
This 344 or SR1136SW cell is low drain and unsuitable for power hungry devices such as watches with backlights, for which you require the high-drain 350. We may sometimes supply the higher capacity, but otherwise identical high-drain 350 cell in place of the 344,
The 343 is a mercuric oxide cell of the same dimension. The 343 mercury cells are no longer manufactured because of their toxicity and environmental unfriendliness. Although the electrical properties are slightly different, if your requirement is to replace a 343 or MR42, you have little option but to use this silver oxide 344 or SR1136SW in its place One alternative that is specially designed for watches is the Accucell-1 battery with built in voltage reduction. For more information, find out about mercury replacement batteries.
The 344 or SR1136SW is commonly used in Accutron watches as a 343 or MR42 replacement. Use them in your Accutron 218, 230, 224 & 219 and in your Omega f300.
MARC-RENE
Nombre de messages : 561
MessageSujet: Re: quelle pile pour une électro mécanique Hermes?   quelle pile pour une électro mécanique Hermes? EmptyMar 10 Mar 2009 - 23:06
AG10/LR1130
Si ces montres t'intéresse il y a:
http://www.electric-watches.co.uk/make/hamilton/electronic/electronics.php
http://www.mechanikus.hu/_p_cali_elec.htm
Touts ces montres électromécaniques me plaisent beaucoup.
Elles représentent les montres High Tech de mon enfance (Lip Nautic Ski en tête).Elles ont souvent un look très spécial et permettent de s'amuser pour pas très cher.
Cordialement,
ChP
ChP
Nombre de messages : 2693
MessageSujet: Correspondances   quelle pile pour une électro mécanique Hermes? EmptyMer 11 Mar 2009 - 16:58
Un tableau de correspondances
aMicalement
quelle pile pour une électro mécanique Hermes? Batter10
machinchouettetrucbidule
Nombre de messages : 1725
MessageSujet: Re: quelle pile pour une électro mécanique Hermes?   quelle pile pour une électro mécanique Hermes? EmptyJeu 12 Mar 2009 - 10:10
à remplacer par une renata 344 ou une energizer 344/350
et chuis sur de mon coup Mr. Green ...
