 Tourbograph “Pour le Mérite” Lange & Sohne
5 participants
Nombre de messages : 57511
Tourbograph “Pour le Mérite”  Lange & Sohne Empty
MessageSujet: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyLun 6 Mar - 18:58
Tourbograph “Pour le Mérite”  Lange & Sohne Lange605_1
Tourbograph “Pour le Mérite”  Lange & Sohne Lange605_3
Tourbograph “Pour le Mérite”  Lange & Sohne Lange605_2
Tourbillon avec système de transmission à fusée et chaine et fonction chrono à rattrapante.
TOURBOGRAPH “Pour le Mérite”
Platinum watch (41.2 mm diameter x 14.3 mm height) equipped with a Lange manufacture Calibre L903.0 movement, manually wound, hand assembled and decorated, plates and bridges of untreated German silver, precision-adjusted in 5 positions. 465 parts plus more than 600 chain parts, shock-proof glucydur-alloy screw balance, Nivarox 1 hairspring, 21,600 semi-oscillations per hour, 36-hour power reserve, sapphire crystal front and back, silver dial. Functions: hours, minutes, power reserve, one-minute tourbillon with fusée-and-chain transmission, chronograph with rattrapante function. Chrono push-button at 2 o’clock, reset button at 4 o’clock, rattrapante push-button at 10 o’clock, crown for winding and setting time.
The fusée-and-chain
The most complex and exclusive wristwatch ever made by A. Lange & Söhne, the Tourbograph is a combination of extraordinary complications, one of which is the intricate fusée-and-chain mechanism which takes into account a circumstance subject to the laws of physics: the mainspring of a mechanical watch does not deliver the same torque when fully wound as when nearly unwound. The power in the final phase of unwinding weakens and can cause rate inaccuracies. Hence the mainspring barrel and the fusée in the Tourbograph are interconnected with a delicate chain consisting of 600 parts. Whilst the watch is wound using the crown, the chain is wound up on the tapered fusée and the spring in the barrel becomes taut. The spring’s power is delivered to the movement via the fusée with constant torque. The mechanism relies on the lever and fulcrum principle discovered by Archimedes … when the mainspring is fully wound and exerts its full force, the chain pulls at the smaller circumference – or lever – of the fusée and when the mainspring’s power declines, it pulls at the larger circumference of the fusée.
This ingenious mechanism improves the rate accuracy of the watch across the entire power reserve range. A planetary gear train comprising 38 parts, with a diameter of 10 millimetres, found inside the fusée, keeps the movement running even while the mainspring is being wound.
The tourbillon
As Lange underline, the tourbillon no longer plays a pivotal role in a wristwatch, given that it was initially created by Breguet to compensate for the influence and cumulative effects of gravity on the balance of pocket watches. This problem doesn’t exist with wristwatches as they are in constant movement, nevertheless, the fascination of a tourbillon’s orbital motion continues to enthral watch aficionados – not to mention the master craftsmen who create them. This elegant tourbillon has a decoratively curved, mirror-polished steel tourbillon cage comprising 84 finished components that weigh less than half a gram. Another special feature is that the staff of the filigree cage is crowned on both sides with a diamond endstone.
The tourbillon contains the escapement and rate-regulating elements such as the pallet lever, the balance and the hairspring and this complex assembly rotates about its axis once a minute.
The chronograph
The chronograph with rattrapante function is the very pinnacle of mechanical timing technology. The mechanism, positioned directly behind the sapphire crystal caseback, is one of the most beautiful assets of a mechanical movement. The twin sweep seconds hands allow additive time measurements of up to 30 minutes as well as, concurrently, the measurement of any number of lap times. This complex function is controlled by the pushbutton at 10 o’clock.
For stopwatch enthusiasts, the Tourbo-graph features two classic column wheels in an elaborate mechanical sub-system to precisely control the two chronograph functions.
The finishing touches
The Tourbograph “Pour le Mérite” is an exceptional timepiece that takes 30 days to assemble, resulting in a total output of 12 pieces a year. Each and every watch is embellished by hand and the decoration of the delicate tourbillon bridge alone takes two days for Lange’s specialists. For the manual circular graining process involving the plates and bridges, 14 different tools are used to obtain the desired perlage effects. The result is not only a chef d’oeuvres of mechanical timekeeping, but also a visual work of art.
101 of these masterpieces will be produced, the first 51 will be made in platinum, followed at a later date by a second series of 50 watches in gold.
The attribution of “Pour le Mérite” in the watch name, refers to the order of merit inspired by Alexander von Humboldt and sponsored by King Frederick William IV in 1842 for outstanding, predominantly scientific accomplishments.
Lange’s master watchmakers finally brought the Tourbograph “Pour le Mérite” watch to maturity in-house, in keeping with Günter Blümlein’s original concept. The most complex and exclusive wristwatch ever made by A. Lange & Söhne, it is clearly much more than a watch equipped with a tourbillon and certainly more important than just a chronograph. It is fitting therefore, that this remarkable timepiece has been dedicated to one of the watch industry’s most profound visionaries.
http://www.europastar.com/europastar/headlines/article_display.jsp?vnu_content_id=1002115628
http://www.alange-soehne.com/en/__stage/home/home.php
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyLun 6 Mar - 19:41
bonjour à tous,la montre aurait pu etre exceptionnelle,si il n'y avait l'ouverture sur le cadran,chez patek le tourbillon est visible par le fond,à croire qu'il sont les seul à savoir à quel point un beau cadran et son boitier font l'esthetique d'une montre.
Tokage
Tokage
Nombre de messages : 8720
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyLun 6 Mar - 20:08
'Jour,
Je suis un peu de l'avis de Sissou. D'un point de vue purement esthétique, cette ouverture n'est pas très heureuse et le pont en travers est encore moins. De plus, d'un point de vue pratique, le bouton de rattrapante à 10 heures n'est pas positionné au mieux, 8 heures aurait été plus ergonomique à mon sens. Reste un mouvement extraordinaire : la chaine avec ses 600 composants me laisse tout esbaudi... Si l'ouverture du cadran permet de voir ladite chaine, je lui pardonne tout !
Elle n'est pas parfaite, mais elle me plait bien !
Cordialement,
Nicolas
Maurice Boissard
Nombre de messages : 636
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 5:47
m'ouais, ouverture loupée et chiffres coupés....mais bon, j'ai porté des montres plus pouraves que cela.....
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 8:27
De toutes les façons, il ne s'agit que d'une montre "image" dont l'objectif est de mettre la technique en avant. Le prix est totalement hallucinant, voire déconnant mais le travail d'Anthony de Haas est intéressant.
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 8:42
Cette montre est un délire horloger et mécanique dans le bon sens du terme. Pas une montre pour acheter mais un luxe que la marque s'est offerte pour faire avance sa propre connaissance et maitrise technologique et qui profite à son image.
Elle plais , elle ne plait pas ce qui importe c'est le niveau technique de la prestation qui est je trouve totalement délirant.
C'est à sa façon la montre que Bréguet fit pour Marie Antoinette, une oeuvre juste pour le plaisir de faire de la belle mécanique et moi j'applaudis.
Quelle chance de vivre dans une époque où on maitrise ça et de pouvoir en parler ensemble thumleft
Tokage
Tokage
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 8:50
'Soir Zen,
C'est vrai que le contenu technologique, que je comprends juste assez que pour être admiratif, a de quoi fasciner. J'y reviens encore, mais rien que l'idée qu'ils ont dû "construire" une chaine de 600 composants tous plus minuscules les uns que les autres ! :cheers: :cheers: :cheers:
Bon, elle n'est pas parfaite mais elle ressemble fort à ces chefs d'oeuvre que faisaient les compagnons pour devenir maîtres en démontrant la maitrise qu'il avait de leur art.
Cordialement,
Nicolas
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 10:59
si à la place d'un tourbillon,que méme les chinois savent faire,ils avaient fait une répétition minute,ça aurait changer la donne. pirat
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:00
Ce tourbillon là est hors de portée des Chinois pour longtemps je pense...
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:08
voila des oeuvres d'art!
Tourbograph “Pour le Mérite”  Lange & Sohne Armin46ks
Tourbograph “Pour le Mérite”  Lange & Sohne Armin58mt
Tourbograph “Pour le Mérite”  Lange & Sohne Armin69fm
Tourbograph “Pour le Mérite”  Lange & Sohne Armin76gi
EMPRUNT SUR TZ
Bruno Brazil
Nombre de messages : 790
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:14
Je ne suis pas d'accord avec les autres avis...
Cette montre a finalement la meilleure disposition, et ce pour 3 raisons...
1 : le travail fait au niveau de la cage de tourbillon est phénoménal, elle doit absolument être visible. J'ai la chance d'être parmi les quelques personnes qui l'ont vue en vrai, et je peux vous dire que ils ont choisi, à chaque fois, de faire ce qu'il y a de + difficile, uniquement "pour le mérite". Cette cage est travaillée à la main, à la lime carrément, chose qu'on ne voit + par ailleurs que chez les horlogers indépendants. Chez L&S il n'y a qu'un seul horloger qui sache la faire !!! il n'a pas interêt à leur claquer dans les pattes...
2 : Cette montre se place dans la lignée directe du 1er "pour le mérite". A ce titre, elle se devait de garder les traits les + caractéristiques de la montre initiale, à savoir la cage, le système chaine & fusée et l'ouverture de cadran très spéciale.
3 : Au contraire de la PP, on a ici une double complication, finalement assez peu compatible avec un affichage groupé. Gerber l'a fait (tourbillon avec chrono rattrapante), mais ça fait vraiment fouillis et etriqué. La solution adoptée permet finalement d'apprécier chaque partie à sa juste valeur, tourbillon ET chrono rattrapante. D'ailleurs, la partie chrono est à un niveau de qualité de realisation hallucinant, même si je trouve la finition L&S un peu trop tape à l'oeil, trop "germanique".
Le SEUL défaut de cette montre est autre : ils n'ont pas réussi à rendre visibles la chaine & la fusée. Mais Anthony a eu beau essayer, il ne l'a pas réussi, et c'est son seul chagrin là-dessus...
D'ailleurs, vous verrez bientôt, mon petit doigt me dit que ils nous préparent encore un truc de derrière les fagots... hummm...
Bruno
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:15
Je pense que tu t'égares complètement.
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:19
Je suis bien d'accord avec Bruno et je rajouterai que (même si ça n'a rien à voir avec la montre) Anthony de Haas est quelqu'un d'extrêmement charmant et plein d'humour. J'avais beaucoup apprécié ses explications "moins langue de bois" lors de la visite chez Lange.
Bruno Brazil
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:22
Tout à fait charmant, et encore + si tu le fais boire quelques vins, et un ou 2 cognacs par dessus !!
Bruno
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:30
je ne vois pas en quoi je m'égare,je n'aime pas les tourbillons coté cadran, ça se respecte.
il faut absolument dire que c'est parfait...?si il etait derriere le fond saphir elle pourrait presque l'étre.
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 11:38
Non, c'est pas le fait de pas aimer (tu en as le droit et esthètiquement c'est loin d'être ma Lange préférée, je n'aime pas les cadrans ouverts de toutes les façons) mais le fait de comparer avec de la production chinoise.
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 18:59
bonjour FX,je ne risque pas de compararer, cette montre avec une chinoiserie, c'etait pour la complication.
a ce sujet en buvant mon café je lisai ,un article sur la minute repeater "Antoine LeCoultre" ou il disait que le tourbillon etait vulgariser, et que les clients qui avait mis des fortunes dans leur montre il y a 5 ans,ne souhaitait plus en porter.
bonne matinée à tous.
Tokage
Tokage
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMar 7 Mar - 20:11
'Jour,
Ce que j'aime avec cette montre, en dehors des remarques que j'avais faites sur l'esthétique ou l'ergonomie, est qu'elle... remet les pendules à l'heure. Des milliers de gens ont acheté des tourbillons par pur snobisme, parce que c'était cher, parce c'était rare, etc. et puis, horreur, cette complication s'est "démocratisée" ! Cela arrivera dans un futur +/- proche avec la répétition minute ou je ne sais quelle autre complication. Malgré cet effet de mode, L&S nous sort cette montre qui prouve que l'horlogerie dans son acception la plus noble a encore de beaux jours devant elle et qu'un tourbillon, avec ce degré de réalisation, ou pas d'ailleurs, n'est pas "has been". En gros, tout le monde peut faire des bagnoles, mais il y a une marge entre la Logan et une Audi S8 (Zut ! Ce ne sont que des emboiteurs, c'est un V10 italien Mr. Green ).
Bon, reste que ce n'est pas la plus belle... Wink
Cordialement,
Nicolas
philou
philou
Nombre de messages : 517
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMer 8 Mar - 7:44
Bonsoir.
Loin de toute polémique, je voulais simplement dire que je trouve cette montre extraordinaire tant sur le plan de l'esthétique que sur la conception.
Je suis quand même curieux d'en connaitre le prix. Alors si quelqu'un a le renseignement, celà me ferait plaisir.
MessageSujet: Re: Tourbograph “Pour le Mérite” Lange & Sohne   Tourbograph “Pour le Mérite”  Lange & Sohne EmptyMer 8 Mar - 8:33
@philou a écrit:
Bonsoir.
De mémoire, aux alentours de 380.000 euros. Lorsque je parlais de prix déconnant, je voulais dire que j'aurais vu plutôt aux alentours de 250.000 euros. Mais à ce niveau on compte plus !
