 omega speedmaster 1964
omega speedmaster 1964 Empty
MessageSujet: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 6:13
vue sur MWR:
1964 Omega Speedmaster. 105.003 -64. cal.321. Serviced.
For no reserve auction:OMEGA SPEEDMASTER 1964. No crown guards. Cal. 321. Rare. Model: 105 003-64.
100% all original parts make and model 1965. NASA tested the model: 105 003 in 1964. NASA independently (without the makers knowledge) tested several leading brands including, Rolex, Breitling, Omega....etc to name a few. Only the Omega Speedmaster 105 003 passed all the stringent NASA tests. Of course the rest is history....... 1st and only watch ever to be worn on the moon etc..... In late 1965 Omega changed the Speedmaster putting crown guards on the case and writing PROFESIONAL on the dial to commemorate their association with the NASA space program. That model is: 105 012. However this watch for sale has the same 321 calibre movement and case that NASA actually passed. This is a very rare and highly collectable watch.
Ok lets take a closer look, superb dial and hands never touched. The crystal is free of scratches as is the whole watch. The case is Solid stainless steel. Looks new on the wrist. This is the best all original case you will see. No dints or scratches. There is no metal corrosion any where on this watch even in the case back threads where it screws down. Rare! Never had water damage. The 321 movement is original to the watch. Just serviced it is date stamped 20527541. All parts original onto itself. Fantastic quality manual wind watch. The watch is working perfectly like new. Very accurate time keeping. All chronographs work and reset exactly as they should.
This watch comes with money back authenticity guarantee and a 1 year all mechanical parts service guarantee. Bid with confidence.
The manual wind calibre321 movement was completely stripped; Ultra Sonic Chemical cleaned and then oiled and re-built. Grade A++ service.
http://www.mwrforum.net/cgi-bin/mwr.pl?read=174119
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 7:11
Je ne vois pas le truc...
Elle est partie à 2500 € avec les frais de port, sans certificat ni garantie Omega, après un nettoyage "costaud", et un "entretien" par qui ?.
Elle est en très bon état de présentation cosmétique au premier regard.
Les angles ont l'air ultra adoucis, mais c'est peut-être les photos.
"Entièrement faite avec des pièces originales" peut aussi s'appliquer à une montre reconstruite avec uniquement des pièces Omega de stock...
Bref, quelle est la question ? Tu as un doute sur la montre ?
Å
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 7:18
Effectivement j'ai oublié mon commentaire. Boulet
Ma question concernait les angles de la boite, mais Mnementh a déjà répondu!
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 7:20
Faut demander à JM pour les speeds. Twisted Evil sinon, l'autre affreux de Zen en a une en bon état... grrrr :lol!:
Å
jean-michel
jean-michel
Nombre de messages : 6712
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 7:34
les angles de la boite : facile ravagé par un polissage ... comment dire ? aggressif
voici ma 105.003 tu pourra voir la différence :
omega speedmaster 1964 Jm1050032
A+
JM
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 7:43
Effectivement; la différence est saisissante. Merci pour la photo Jean-Michel.
milwatch
milwatch
Nombre de messages : 4760
MessageSujet: Re: omega speedmaster 1964   omega speedmaster 1964 EmptyLun 21 Aoû - 20:13
de mon point de vue, la longines presentée ici est tres interessante
ce n'est pas un modèle de l'armée tcheque, mais un de de l'armée allemande (signature RLM) bien plus rare que ses soeurs tcheques
la iwc WWW est superbe bounce
