 Clé USB Horlogère par Rob Smith
Blanchefontaine
Blanchefontaine
Nombre de messages : 406
Clé USB Horlogère par Rob Smith Empty
MessageSujet: Clé USB Horlogère par Rob Smith   Clé USB Horlogère par Rob Smith Empty6/6/2009, 02:39
The Mechanical Memory Key was handmade by UK Artist Rob Smith and took Rob about 12 hours to make, as you can see from the photo the case is made from wood and it features parts from 6 different pocket watches.
Description
So this is Mechanical Memory key Number 3. Its probably, in my opinion, my most successful so far. It has however taken an age to finish (approx 10-12 hours) mainly due to the detail and having to harvest the pieces from the watches myself - I think I probably used parts from around 6 different pocket watches (from brand new ones to watches over 100 years old).
The key is made out of purple heart & has approximately 26 Ruby's which look great when the key catches the light, & when the Keys plugged into a USB, it glows green from underneath the gears giving the key a good sense of movement.
The key's stated size is 16GB (as with all Flash memory sticks, some of that memory holds the 'Plug & Play' drivers) & runs at a fantastic 110x!
Un concept que je trouve très intéressant. Cette clé mise en vente a 165 USD est partie très rapidement...
Clé USB Horlogère par Rob Smith Mechanical-memory-key_1
Clé USB Horlogère par Rob Smith Mechanical-memory-key_2
Clé USB Horlogère par Rob Smith Mechanical-memory-key_3
Vue sur Etsy
MessageSujet: Re: Clé USB Horlogère par Rob Smith   Clé USB Horlogère par Rob Smith Empty6/6/2009, 10:33
rahhh mais pourquoi avoir collé une pièce de quartzzzz affraid sans ça, elle aurait été très belle cette clusb
» Smith and Son
» R.W Smith
» Smith & Son ...
» Smith & Wesson
» Roger W SMITH...
