| Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR | |
+7Vert TechTime steyr chiouahouah cisco Tokage ZEN 11 participants |
ZEN Rang: Administrateur
| Sujet: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 7:36 | |
| - Citation :
- Two time zones utilizing a 24-hour hand are placed either side of the tourbillon at 5 and 7 o’clock and can be set by pushbuttons on the side of the case. The time zone indicator on the right is conceived for travelling eastwards and therefore moves one hour ahead at each press of the corrector on the right side of the case. The time zone indicator on the left is designed for travelling westwards and therefore moves back an hour with each press of the corrector on the left side of the case. Just above the tourbillon at 6 o’clock, is the year indicator which functions from 0 to 999 and then continues along its merry way indefinitely. Now that’s a world-first.
There is a moon phase indicator set just below the date indicator at 12 o’clock that works to a precision of 6.8 seconds per lunar month. That represents an error of a mere 24 hours every 1000 years. Traditional perpetual calendars make that error every 4 years. http://www.europastar.com/europastar/headlines/article_display.jsp?vnu_content_id=1003468258 _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
Tokage Membre référent
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 8:58 | |
| On dirait un flipper... Ok, je Nicolas |
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 9:23 | |
| sans rien enlever au travail de Franck Muller je trouve cette réalisation un poil chargée... Antoine |
cisco Puits de connaissances
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 9:27 | |
| il a déconné...le boulot est pas fini Y'avait encore de la place au dessus du 10 et du 2 pour mettre un planétarium et les cycles de sa femme
chiouahouah Membre référent
Nombre de messages : 5530 Localisation : sais plus où j'habite !! Date d'inscription : 08/11/2006
| Sujet: sans autres commentaires Jeu 4 Jan 2007 - 9:34 | |
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 11:19 | |
| LA montre pour les réunions pénibles !
... utile pendant certains repas de famille aussi.
Å
Il y a du travail ceci-dit. |
steyr Membre référent
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 11:49 | |
| Le point rouge sur le "2", c'est une indication, une erreur du peintre, ou une implantation pour une aiguille oubliée ? Faire une complication pour faire une complication, ça devient une bête de concours, mais ça ne vaudra pas une seule et unique complication bien mise en valeur, à mes yeux. En revanche, pour les réunion, je ne dis pas Encore qu'il me semble avoir déjà fait mieux, avec une roulette dans une montre ou quelque chose dans le genre ... Christian. |
TechTime Modérateur
Nombre de messages : 4171 Age : 101 Date d'inscription : 28/09/2006
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 11:59 | |
| Trop c'est trop... Ca me fait penser à ces limousines de 10m de long avec Jaccusi , bar et salle de cinéma à l'intérieur Quand la complication devient trop....compliquée ,elle perd inévitablement son intéret ! Jean-François _________________ "Les bonobos deviendront moins bonobos et les humains moins humains.Nous ne sommes pas si différents que ça." William Fields , Fondation des grands singes de l'Iowa.
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 12:18 | |
| Vous me pardonnerait le travail de et la photo trop petite, mais comme ça c'est mieux non... https://servimg.com/view/10064871/1 |
Vert Membre super actif
Nombre de messages : 420 Localisation : Bruxelles.be Date d'inscription : 19/10/2006
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 12:36 | |
| 13 aiguilles, sauf erreur, y a de quoi s'occuper rien que pour tout régler, déja |
Guardala Passionné absolu
Nombre de messages : 2689 Localisation : Lyon Date d'inscription : 05/12/2005
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 12:39 | |
| Ceci nous apprends 2 choses sur Franck Muller: - ils savent faire de la complication. - il va falloir progresser sur le design. |
Bruno Brazil Animateur
Nombre de messages : 786 Age : 52 Localisation : Loir et Cher Date d'inscription : 12/10/2005
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 13:26 | |
| P'tain le merdier... C'est pas le tout de mettre les complications dans une boîte, encore faut-il savoir les maîtriser... N'empêche, il a bien evolué, le 3133 !!! BB |
LUDOR43-74 Pilier du forum
Nombre de messages : 1976 Date d'inscription : 01/10/2006
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 16:48 | |
| Moi je crains pas, c'est une marque étrange c'est vrai mais ça n'empeche que je salue la prouesse |
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 17:05 | |
| c'est pas un des 1500 calibre poljot? |
Eric Permanent passionné
Nombre de messages : 2177 Localisation : Var Date d'inscription : 03/07/2006
| Sujet: Re: Franck Muller - AETERNITAS VERSION II PERPETUAL CALENDAR Jeu 4 Jan 2007 - 17:19 | |
| 13 aiguilles , 4 bouttons J'espère que lemode d'emploi est claire. Finalement le fond transparent à trouvé son maître |
