 Maurice Lacroix Memoire 1 Unveiled
le plombier
Horloman
TechTime
cisco
steyr
OdeX
Did666
Tokage
Boogie
Ratkiller
16 participants
Nombre de messages : 57505
Maurice Lacroix Memoire 1 Unveiled Empty
MessageSujet: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 7:11
Maurice Lacroix Memoire 1 Unveiled Memory1
Technical Specifications
Movement: Maurice Lacroix manufacture movement, mechanical 128 with automatic, bidirectional winding system, hand-decorated with vertical or circular satinized sections and PVD surface refinement in tantalum colour; wheels gold-plated or with black PVD surface refinement; 48 jewels (25 transparent, 23 ruby-coloured); ML precision adjustment with “vis sans fin” (endless screw) system; transparent ML balance with white gold ring; KIF shock protection; Nivaflex M mainspring (exclusive to Maurice Lacroix); beating at 28,800 bph.
Functions: Chronograph with mechanical memory function, real time (time mode) and measured time interval (chrono mode) use the same indications (disc and hands); date indication with disc, indication of minutes and seconds with central hands, mode indication with hand at 3 o’clock.
Case: 49mm case diameter available in 18kt White gold and palladium; double sapphire crystals with anti-reflective coating on the inside, screwed caseback with display (8 screws); water resistance to 50 meters
Dial: Black and silver color; 4 parts assembled by hand, functions indicated on different levels, transparent, mineral-based hours disc with anti-reflective coating; minutes hand, hours disc and hours indication at 12 o’clock with white, luminous coating giving a blue radiance; applied and facetted index marks.
Watchband: Hand-sewn, matte alligator leather with buckle in 18kt white gold and palladium.
Ratkiller
Ratkiller
Nombre de messages : 6072
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 7:49
Très originale dans la conception et le présentation, j'aime beaucoup le concept !
Une usine à gaz, mais l'effort sur la présentation du calibre est intéressant, avec les rouages dorés ou traités PVD.
Toujours ce Maurice qui gêne un peu, mais je ferais l'effort si j'avais un bras en rabe.
[edit] j'avais zappé les 48mm, dommage pour mon poignet ! Mais elle est quand même belle.
Edit : bras, pas bas Wink
Boogie
Boogie
Nombre de messages : 6611
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 10:10
Mon Dieu, que ça ne me plaît pas, pour rester poli Embarassed
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 10:13
A voir en vrai impérativement !
Ratkiller
Ratkiller
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 11:14
Seront-ils présents au salon de ce week-end à Paris ?
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 11:18
Oui, ML sera présent mais je ne sais pas si cette montre y sera.
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 11:19
j'espere! je suis pas fan du boitier mais c'est un sacré bout de montre, faut absolument la voir en fonctionnement.
Tokage
Tokage
Nombre de messages : 8715
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 14:47
Tres belle idee de montre qui permet a ML de confirmer sa volonte de tendre vers le modele de la "manufacture". La montre semble enorme cependant : rapportee aux 49mm de diametre, la hauteur doit etre consequente. A voir en vrai sans oublier le caractere special de cette montre.
Nicolas
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 17:59
Je souhaite bien du courage à l'horloger qui ferra la révision/réparation de l'usine à gaz...
à mettre en rapport avec le topic sur le coût de SAV et la fiabilité de nos montres.
https://forumamontres.forumactif.com/forum-general-de-discussions-horlogeres-f1/qu-est-ce-qui-justifie-le-prix-des-revisions-t27113.htm
H3
Did666
Nombre de messages : 37886
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyJeu 6 Déc - 18:44
A voir en réel et au poignet, mais j'aime assez l'idée.
OdeX
OdeX
Nombre de messages : 1808
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 0:11
H3
... Dans la même idée, à mettre en rapport avec le topic "portez-vous au dessus ou au desosus de la chemise ?", parceque vu l'épaisseur...
affraid
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 1:02
petite video de présentation ici
http://www.memoire1.ch/
steyr
Nombre de messages : 5738
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 1:37
La video, le site, et l'ensemble des visuels ont été faits par la petite société www.i-reel.fr à Paris (cocorico). Je me permets de souligner leurs travaux car à mon sens ils ont une belle longueur d'avance dans le domaine du film promotionnel horloger. Sur ce coup, ils ont beaucoup travaillé pour créer un univers dans lequel vient finalement s'intégrer la montre (petit reproche : elle arrive un peu tard). Une approche un peu différente qui semble faire des émules et de plus en plus de clients leurs demandent de faire du "Hautlence-like". J'avais vu cette video il y a deux mois, dans des conditions qui permettaient d'apprécier la musique et la qualité d'image... Bravo à eux !
Christian.
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 1:41
tout à fait d'accord, vidéo promotionnelle de belle qualité.
Nombre de messages : 4814
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 1:44
Techniquement très intéressant, le design plus discutable ... en tout cas bravo car elle a une vraie identitée propre Impec
http://www.cronovestis.com
steyr
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 1:52
Effectivement, j'ai également une petite préférence pour leurs campagnes
- 1911 BTR : http://www.ebel.com/1911BTR/BTR_French.html (télécharger la video)
- et bien évidemment HLs http://www.hautlence.com/Hautlence.html section download
Christian.
cisco
cisco
Nombre de messages : 4378
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 2:52
sacre boulot de conception et d innovation, triple bravo a Momo bravohap bravohap bravohap
C est surement peu portable (doux euphemisme) mais ce n est pas le but principal de la montre.
Tres belle demonstration technologique, je serai moi aussi bien curieux de la voir tourner
Par contre cette "immense colonne" au milieu du mouvement, ca fait un peu bizarre ?
steyr
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 3:01
Ce sont les axes des aiguilles. Ils sont ici particulièrement prononcés car le chemin de fer et les index où se situent les indications horaires est réhaussé. On voit que l'indication du jour se fait sur ce plan incliné. C'est esthétiquement très original. Je languis de pouvoir me faire une idée de ce que cela donnera en vrai.
Christian.
TechTime
TechTime
Nombre de messages : 4183
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 4:02
J'ai peur que la montre soit énooooorme.
Mais j'aime bien cette idée d'utiliser la complication chronographe avec les aiguilles minutes seconde classiques et un disque pour les heures (enfin si j'ai bien tout compris).
Au niveau du design ce n'est pas trop ma tasse de thé mais comme il a été souligné : A voir en vrai.
Le film est un modèle du genre.
Si quelqu'un sait de qui est la musique ??
Jean-François.
"Les bonobos deviendront moins bonobos et les humains moins humains.Nous ne sommes pas si différents que ça." William Fields , Fondation des grands singes de l'Iowa.
Horloman
Horloman
Nombre de messages : 532
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyVen 7 Déc - 4:08
Un lien sur le site officiel:
http://www.memoire1.ch/film.html
http://www.les-artisans-horlogers.com/
steyr
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptySam 8 Déc - 7:02
En général, I-reel fait appel à un musicien de Sèvres. Mais là, c'est chanté. Je pense néanmoins que c'est toujours du sur-mesure... C'est pas évident de trouver une musique qui s'adapte bien, il vaut encore mieux la faire faire. Je leur demanderai à l'occasion.
Christian
TechTime
TechTime
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptySam 8 Déc - 7:56
Merci Christian Impec
Jean-François.
le plombier
le plombier
Nombre de messages : 4402
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptySam 8 Déc - 23:25
Voila le genre de truc qui risque de couter un oeil à la revision.Sinon à voir en vrai ,le fonctionnement doit être diabolique .
Coté taille 49mm ........et l'épaisseur???
michelro67
michelro67
Nombre de messages : 1220
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyDim 9 Déc - 0:00
je pense qu'ici, c'est comme un prototype de voiture, le design excentrique compte peu, ce qui compte par contre est l'exploit horloger qui semble considérable
Chonum
Chonum
Nombre de messages : 638
MessageSujet: Re: Maurice Lacroix Memoire 1 Unveiled   Maurice Lacroix Memoire 1 Unveiled EmptyDim 9 Déc - 4:44
Une vraie nouvelle complication, cela n'arrive pas tous les jours Impec
» maurice lacroix memoire 1
» Maurice lacroix et la 1ère montre méca à mémoire
» J'en ai rêvé :maurice l'a fait!!! (maurice lacroix)
» Maurice FRONTEAU Maitre artisan horloger; devoir de mémoire?
» Maurice Lacroix.....
