| F.P. Journe Octa Moonphase & Power Reserve | |
ZEN Rang: Administrateur
| Sujet: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 20:07 | |
| Un nouveau calibre et 2 modèles Octa CALIBRE 1300-3 - Citation :
- Automatic Octa watch with date and power-reserve indicator Bridge side - Under-dial view
Indications: Central hours and minutes - Small seconds at 4:30 - Large date - Power-reserve indicator at 9 o’clock
Dimensions: Total diameter: 30.8mm - Casing-up diameter 30.4mm - Total height: 5.86mm
Movement features: 15-tooth, No. 8 escape-wheel. Free-sprung balance with four adjustment weights Flat Anachron balance- spring Mobile stud holder - Pinned stud - Spring laser - welded to the collet - Three-position crown - Slipping mainspring - Off-centre winding rotor
Winding speed on rotator without mainspring slipping: 274 anti-clockwise rotations/24 hours - Citation :
- Characteristics:
Unidirectional automatic winding - Instantaneous date change - Date setting by the crown in position 2 – Time setting by the crown in position 3 Balance: Frequency: 21,600v/h (3Hz) - Inertia: 11.0 mg/cm2 - Angle of lift: 52° Amplitude: 0h dial up: >280° - 24h dial up: >220° Time-keeping autonomy: 160 ± 12 hours Jewels: 27 Finish: High grade - Circular stripes on the bridges - Baseplate circular-grained - Polished and bevelled screws - Pegs with rounded, polished ends Number of parts: Movement: 233 - Cased up on leather strap: 268 Vu sur Tz _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
titof70 Passionné de référence
Nombre de messages : 3547 Age : 54 Localisation : Va savoir... Date d'inscription : 22/01/2006
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:03 | |
| Ok, certains vont dire que le cadran est plus encombré maintenant. Et c'est vrai. Mais, bien que personnellement, j'ai toujours trouvé que la définition précédente était très belle, je suis toujours resté sur ma faim : il lui manquait quelque chose. Là je suis sous le charme. Aurais-je trouvé mon graal (provisoire) ? La version avec la phase de lune est sublime. Quant aux mouvements, que dire si ce n'est que c'est toujours aussi fantastique, tout en or et superbement fini. |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:05 | |
| Incroyable ! Après des semaines d'horreurs, des nouveautés qui me plaisent ! Très belles ces Journe et les complications équilibrent le cadran. |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:08 | |
| ouai..bon c est sur c est pas laid..maintenant elle ne reprend pas les codes visuels des "vrais" Journe..alors c est sur c est pas laid..mais bon je me tape pas le cul par terre pour autant. Bon de dos c est sur c est vachemment sympa et ca change des anciens mouvement en laiton !
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:14 | |
| j'aime vraiment bcp, surtout la moon phase. et pour faire le lien avec un post sur l'utilité des fonds transparents celui-ci se justifie pleinement! quel magnifique mouvement!
Antoine |
Xaipe Modérateur
Nombre de messages : 7998 Date d'inscription : 17/05/2005
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:17 | |
| toujours de bon goût, j'ai plus de mal avec le 6 et le 7 renversés. La seconde décentrée c'est un must sous mon angle ! |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:23 | |
| - Xaipe a écrit:
- toujours de bon goût, j'ai plus de mal avec le 6 et le 7 renversés. La seconde décentrée c'est un must sous mon angle !
Oui mais c'est logique, les chiffres tournent toujours dans le bon sens ! C'est comme ma Cabaret le 6 est à l'envers (ou finalement à l'endroit) : C'est ça la haute horlogerie : des chiffres qui tournent toujours dans le bon sens... |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:44 | |
| - Colonia a écrit:
- ouai..bon c est sur c est pas laid..maintenant elle ne reprend pas les codes visuels des "vrais" Journe..alors c est sur c est pas laid..mais bon je me tape pas le cul par terre pour autant. Bon de dos c est sur c est vachemment sympa et ca change des anciens mouvement en laiton !
Pas d'accord avec toi sur ce coup. Tu devrais dire que c'est différent de la première gamme Octa. Même si celles-ci s'appellent "Octa", cela correspond à la gamme "Souveraine", qui est la nouvelle ligne de Journe (cf Sonnerie Souveraine & co). J'adore aussi la gamme Octa, mais c'est positivement inabordable. |
la cave Membre super actif
Nombre de messages : 327 Age : 55 Date d'inscription : 09/03/2007
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 22:47 | |
| je ne suis pas un grand fan de cette superbe maison,mais il faut avouer que ces modeles me plaisent vraiment beaucoup |
simplicity Membre référent
Nombre de messages : 7291 Age : 45 Localisation : Francilia Date d'inscription : 20/10/2006
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 23:06 | |
| en fait, il aurait du la baptiser : chronomètre souverain à phase de lune , le cadran étant AMHA , plus comparable à celui du CS qu'aux Octa , sauf si je me rappelle bien , que sur le CS , la réserve de marche est à 3 H ; en tout cas , c'est du JOURNE , et du très , très beau : boite et mouvement comme d'habitude . FPJ ne déçoit jamais ses fans : toujours de la belle ouvrage ! Et en platine, j'aimerais bien l'avoir en main . |
alexander mahone Pilier du forum
Nombre de messages : 1651 Age : 103 Localisation : Amsterdam Date d'inscription : 25/11/2006
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 23:17 | |
on a tous eu cette idee au début avec la souvrain ,c'est du Journe sans l'adn pour parler à la Hublot en fait non ,j'ai essayé la souverain en 40mm c'est une trés belle JOURNE avec tout ce qui va avec cette grande maison ,une vraie ,là encore il faut avoir la montre en main ,in vivo veritas comme dirait mon marchand de journaux qui n'a pas fait de latin on remarque quand meme que le père journe il se ramène de plus en plus sur des complications "normales" il en a marre des sav sur les resonances surement |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mar Mar 27 2007, 23:27 | |
on remarque quand meme que le père journe il se ramène de plus en plus sur des complications "normales" il en a marre des sav sur les resonances surement Je suis assez d'accord. Le chrono souverain est vraiment une montre entrant dans la catégorie de celles qu'il faut avoir en main pour pouvoir en apprécier toutes les qualités. J'étais dubitatif jusqu'au moment où j'ai pris le temps d'aller la passer au poignet. J'ai eu beaucoup de mal à la retirer et à sortir de la boutique sans faire une très grosse bêtise. Exactement le même genre de sensations qu'avec la Richard Lange. Elle est d'ailleurs aussi très belle en or rose. Moins froide peut-être. |
nikolo Membre super actif
Nombre de messages : 456 Age : 48 Localisation : Bordeaux Date d'inscription : 12/12/2005
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mer Mar 28 2007, 08:37 | |
| Comme d'hab. Ah ce Journe... toujours aussi beau. Je sais pas si vous avez lu l'article sur http://www.horlogerie-suisse.com/ ... Je ne vois pas exactement en quoi un remontage unidirectionnel remonte mieux qu'un bi... Sinon, c'est vrai que au moins c'est lisible. Parceque les vrai journe, faut tout de même de bons yeux pour lire l'heure. Je suis donc ravi de voir la souverain se compliquer un peu, car certes ce n'est pas la plus interressante du point du mouvement, mais on peut lire l'heure dans les lunettes.... |
Time to Time Membre très actif
Nombre de messages : 183 Localisation : Paris Date d'inscription : 20/02/2007
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mer Mar 28 2007, 08:44 | |
| Est-ce que ce cadran ne manque pas un peu d'harmonie, avec ces indications dispersées un peu partout comme si on les avait aspergées au hasard ?
Pour le coup, le Centigraphe (chrono au centième) que FPJ prépare pour le mois prochain paraîtra très ordonné et beaucoup plus classique avec ses trois compteurs... |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mer Mar 28 2007, 09:03 | |
| "il en a marre des sav sur les resonances surement " J ai lu ca egalement. C est jolie mais parait il pas hyper fiable...Je ne sais pas si c est un defaut sur les 1eres qui a été résolu ou si c est plus structurel.. Pour la matiere ca doit faire contrasté pas mal boite en Pt et mvmt en or ? Colonia |
| Sujet: Re: F.P. Journe Octa Moonphase & Power Reserve Mer Mar 28 2007, 09:38 | |
| Petit détail qui a son importance, le Chronomètre Souverain est à remontage manuel alors que celui-là est à remontage auto.
J'ai l'impression que les montres utilisant un calibre auto s'appele tous octa. |
