Sujet: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 10:44 pm
Source : Horomundi
Press release is as supplied by A Lange & Sohne.
A modern interpretation of Saxon splendour: the new SAXONIA
A. Lange & Söhne has redefined the SAXONIA and with three models has thus created a distinctive watch family with a striking, classically elegant personality. With suave charm and convincing intrinsic values, the members of the re-issued family – the SAXONIA, the SAXONIA AUTOMATIK, and the GRAND SAXONIA AUTOMATIK – are worthy ambassadors of the Saxon watchmaking heritage.
When it was first introduced to a spellbound audience at the Dresden Palace in 1994, the SAXONIA – one of the watches in Lange’s new-era debut collection – paid tribute to Ferdinand Adolph Lange, the founder of the precision watchmaking industry in Glashütte, and expressed deep respect for his Saxon homeland. The location was judiciously chosen, because the history of A. Lange & Söhne began right here: at the court of Saxony’s electors and kings. This is where Ferdinand Adolph Lange began his horological career as the master student of Gutkaes, clockmaker to the Royal Saxon Court. And this is also where Saxon jewellers, sculptors, and watchmakers demonstrated unprecedented prowess under the auspices of Augustus the Strong, one of the most illustrious rulers of the Baroque period. During his reign, Dresden became the mecca for Europe’s most talented artisans, and the “Green Vault”, the court’s collection of treasures, was considered synonymous with Saxon splendour. The three new timepieces presented by A. Lange & Söhne proudly evoke this tradition with “SAXONIA” as their shared family name. Every detail of their lavishly hand-finished movements transports the values of Saxon precision watchmaking from its pioneering days to the present.
The SAXONIA
Just like the Saxon artisans of bygone days, Lange’s master watchmakers are modest individuals who share a passion for perfection. Accordingly, the personality of the SAXONIA is refreshingly understated. Its design focuses entirely on essentials: the sleek contours of the case frame the perfectly legible dial. The sapphire-crystal caseback showcases the exclusive calibre L941.1 movement. Its plates are made of untreated German silver, an alloy composed of copper, zinc, and nickel which in the course of time develops a golden patina. Lange is one of the few manufactories that uses this alloy. Screws that are annealed to a cornflower blue and the synthetic ruby jewels – four of them embedded in gold chatons – create a colourful contrast. The passion and time invested in the finish of the movement parts also belong to the Lange culture. Even surfaces that are concealed after the assembly of the movement are meticulously decorated with refined patterns. The hand-engraved balance cock turns each watch into a one-of-a-kind treasure. The 37.0 millimetre case is crafted from 18 carat yellow, pink, or white gold. The appliques on the dial and the lancet hands are also made of solid gold. The solid-silver dial is available in four different colours.
SAXONIA AUTOMATIK and GRAND SAXONIA AUTOMATIK
The SAXONIA AUTOMATIK and the GRAND SAXONIA AUTOMATIK are endowed with all the quality features that are characteristic for each member of the noble SAXONIA family. Additionally, they are powered by a movement that is exceptional in every respect: Lange’s famous SAX-0-MAT manufacture calibre. The first and last syllables refer to Saxony, its geographical home, and to the automatic winding mechanism. The “zero” in the middle stands for the sophisticated ZERO-RESET feature which causes the seconds hand to instantly jump to zero when the crown is pulled. This is a useful innovation that truly simplifies the synchronisation of the watch with a reference time signal. The SAX-0-MAT is also unique by virtue of its winding mechanism design. Thanks to its reversing and reduction gear train, the delicately embossed rotor in gold and platinum winds bidirectionally. Four ball bearings assure that it transfers its torque to the mainspring with the greatest degree of efficiency. The gearing ratio builds up a sufficient power reserve even on a calm wrist. The fascinating kinetics of the winding rotor and the going train can be admired through the sapphire-crystal caseback. The face of the SAXONIA AUTOMATIK is accented by the Lange outsize date beneath the twelve. The two timepieces are available in white or pink gold as SAXONIA AUTOMATIK with a diameter of 37.0 millimetres or in more prominent versions as GRAND SAXONIA AUTOMATIK with a 40.6-millimetre case.
Data sheet SAXONIA
Movement: Lange manufacture calibre L941.1, manually wound, crafted to the highest Lange quality standards and largely assembled and decorated by hand; precision-adjusted in five positions; plates and bridges made of untreated German silver; balance cock engraved by hand Movement parts: 164 Jewels: 21 Screwed gold chatons: 4 Escapement: Lever escapement Balance: Shock-resistant glucydur screw balance, Nivarox hairspring balance with a frequency of 21,600 semi-oscillations per hour, whiplash precision index adjuster with patented beat adjustment mechanism Power reserve: 45 hours when fully wound Functions: Time display in hours, minutes, and small seconds with stop seconds Operating elements: Crown for winding movement and setting the time Case: Diameter 37.0 millimetres, yellow, white, or pink gold Glass and caseback: Sapphire crystal (hardness 9) Dial: Solid silver, champagne, argenté, black or grey Hands: Yellow gold, rhodiumed gold or pink gold Strap: Crocodile strap with precious-metal Lange prong buckle in solid yellow, white, or pink gold
Data sheet SAXONIA AUTOMATIK and GRAND SAXONIA AUTOMATIK Movement: Lange manufacture calibre L921.4 (SAXONIA AUTOMATIK) and L921.2 (GRAND SAXONIA AUTOMATIK), self-winding, crafted to the highest Lange quality standards and largely assembled and decorated by hand; precision-adjusted in five positions; plates and bridges made of untreated German silver; balance cock engraved by hand Movement parts: 378 (SAXONIA AUTOMATIK) 307(GRAND SAXONIA AUTOMATIK) Jewels: 45 (SAXONIA AUTOMATIK) 36 (GRAND SAXONIA AUTOMATIK) Escapement: Lever escapement Balance: Shock-resistant glucydur screw balance, Nivarox hairspring balance with a frequency of 21,600 semi-oscillations per hour, whiplash precision index adjuster with patented beat adjustment mechanism Power reserve: 46 hours when fully wound Functions: Time display in hours, minutes, and small seconds, with stop seconds, outsize date (SAXONIA AUTOMATIK) Operating elements: Crown for winding movement and setting the time, push piece for advancing the date display (SAXONIA AUTOMATIK) Case: Diameter 37.0 millimetres (SAXONIA AUTOMATIK) Diameter 40.6 millimetres (GRAND SAXONIA AUTOMATIK), white or pink gold Glass and caseback: Sapphire crystal (hardness 9) Dial: Solid silver, argenté, black or grey Hands: Rhodiumed gold or pink gold; seconds hand rhodiumed gold, pink gold or blued steel Strap: Crocodile strap with precious-metal Lange prong buckle in solid white or pink gold
ZEN Rang: Administrateur
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 10:57 pm
Merci François-Xavier . 40,6 mm voilà une taille qui est tout à fait acceptable !
simplicity Membre référent
Nombre de messages : 7291 Age : 45 Localisation : Francilia Date d'inscription : 20/10/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:04 pm
très belle , en effet, mais plutot que" nouvelles ", je pense q"évolution " conviendrait mieux .
j'ote la grande date , j'colle L et S , en arc de cercle à la place , et j'crée une nouveauré. OUAIS, pourquoi pas ?.
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:05 pm
On assiste a un enterrement de premiere classe de la 1815, tout du moins de la 1815 automatique ainsi que de la saxomat... enfin c est l impression que cela me donne.
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:06 pm
Eh oui... comme Patek... un guillochage en plus... quelques mm en plus et hop !
fanfan Membre Hyper actif
Nombre de messages : 570 Localisation : Lyon Date d'inscription : 25/03/2007
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:10 pm
quel bonheur de découvrir la saxonia avec une taille un peu plus conforme aux standards actuels. Tu me l'avais d'ailleurs conseillée FX. malheureusement, une petite déception. Comme toi, j'aime beaucoup remonter mes montres et il est dommage que le grande n'existe pas en remontage manuel...
Mais bon, on va pas chipoter tout de même.
Pour moi, c'est une des plus belle L&S avec la L1.
titof70 Passionné de référence
Nombre de messages : 3547 Age : 54 Localisation : Va savoir... Date d'inscription : 22/01/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:11 pm
Ok c'est du cosmétique mais cela reste néanmoins très beau. J'aime cette élégance épurée.
Et pourquoi enterrement pour la 1815, FX ???
pourquoi donc ? La 1815 n'a pas le même dessin, je pense plutôt à une ligne parallèle non ?
Ratkiller Membre référent
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:13 pm
C'est vrai quoi, il n'y a même pas de courroies pour la transmission !
Difficile de se renouveler.
Et difficile aussi de garder l'esprit de la marque.
Pourquoi changer une équipe qui gagne ?
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:15 pm
Je sais pas... tout ceci me donne quand meme une impression de double emploi au niveau des modeles automatiques.
Quand a une grande a mouvement manuel, il y a la RL mais qui est tres differente ne serait-ce que par la grande seconde, unique dans la gamme.
On verra bien !
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:18 pm
FX , d'accord , d'autres marques évoluent dans la nouveauté, MAIS là : quand j'ai vu la photo, et comme j'avais pas lu le nom du modèle, je me suis dit :
Ils ont juste mis des index à la place des chiffres sur la 1815 !!!!
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:20 pm
peut être mais elle est maintenant sur ma wishlist !
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:24 pm
C est exact mais je la trouve (celle de 37mm) plus jolie que la 1815 automatique penalisee par l espece de cercle interieur sur le cadran. Je suis moins convaincu par le grand modele.
Je suis sur que nous allons avoir des arrets de modeles, je le sens... I feel it in the air...
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Jeu 12 Avr 2007, 11:28 pm
FX : peut-ètre pas ,
peut -ètre que l'an prochain, la nouveauté , ce sera une 1815 à INDEX ? :lol!:
chiouahouah Membre référent
Nombre de messages : 5528 Localisation : sais plus où j'habite !! Date d'inscription : 08/11/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 12:38 am
Me souviens plus du diamètre de la 1815 auto ,ds les37 aussi je crois,ses chiffres arabes et son chemin de fer la rendent bcp + désirable à mes yeux,en + je n'aime pas cette grande date trop rigide qui mange trop le cadran. Belle tocante tout de même mais faut bien pinailler sur FAM (taisez vous au fond!)
Tokage Membre référent
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 9:17 am
J'adore ! Les modifications sont mineures mais c'est bien fait. Une remise au goût du jour comme les Nautilus de PP. Comme a dit je ne sais plus qui (s'il l'a dit) : "La perfection est dans les détails". Bien plus belle en tout cas que la Langematik dont elle marche sur les pieds.
Nicolas
alemmar Passionné de référence
Nombre de messages : 3128 Localisation : marseille Date d'inscription : 24/12/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 10:45 am
du beau, du bon, du Lange, décidement cette marque me plait de plus en plus.
valable Pilier du forum
Nombre de messages : 1839 Age : 51 Localisation : Toulouse Date d'inscription : 09/08/2005
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 10:49 am
Pour moi une marque toujours aussi peu intéressante. Dans cette gamme de prix, je vais chez Patek. Je les trouve tout à fait ordinaires, pas dans le sens péjoratif du terme (synonyme beauf) mais je ne leur trouve vraiment rien de fantastique. Comme quoi les goûts des uns et des autres...
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 10:54 am
La perfection et les détails c est de Leonard le mec qui a joué dans Da vinci Code.
Sinon je plussois mon ami Valable...c est bien fini...normal pour ce prix...mais pour moi ca s'arrete la.
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 10:59 am
je plussois avec l'ami colonia qui plussois l'ami valable ...ama,pour colonia il faut une breguet 5140 plus qu'une patek,cette montre a été créée pour son poignet
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 1:15 pm
Dans cette gamme de prix, que ce soit PP ou Lange ou d autres, ce sont des montres a vivre : on n a pas forcement de coup de coeur instantanne mais on les apprecie chaque jour plus. Ce sont des montres qui devoilent leur charme au fur et a mesure, pas comme certaines qui se foutent a poil des le premier soir.
Une Lange manuelle au quotidien, c est superbe ne serait-ce que par le plaisir du remontage.
Une Patek au quotidien, on decouvre chaque jour un detail...
Ce sont des montres qu il faut essayer, porter et ne pas se contenter des miserables photos de presse que l on voit ici.
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 1:21 pm
Et je souhaitais rajouter une chose : sur le commentaire, la finition est bonne normal pour le prix. Certes mais la finition de ces montres est au-dessus de certaines qui sont dans le meme segment de prix... j ai des exemples a la pelle.
Quand on voit certaines marques qui deviennent "manufacture" depuis hier soir et qui en profite pour faire envoler les prix, on se dit qu en rapport qualite prix (et pourtant je n aime pas ce concept), les manufactures traditionnelles sont plus abordables.
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 2:34 pm
Pourquoi parler à demi-mots ? Tu préfères les Lange, ok soit, c'est ton droit. Moi je préfère mes Panerai manufacture d'avant hier et emboiteur depuis toujours. Tout le monde est content. C'est l'essentiel. Bise.
MarcDeBeaucaire Permanent passionné
Nombre de messages : 2322 Date d'inscription : 31/03/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 3:17 pm
Booah, pour éviter de devenir chèvre, il est effectivement + sain d'être content des montres que l'on possède
Mais le débat partait plutôt de: "à ce prix là je vais chez Patek" et "C'est bien fini, normal pour le prix"
Autour de 12.000 euros, qu'est ce qui est mieux fini entre une Calatrava d'entrée de gamme, un 1815 en platine et une Luminor en or?
Nombre de messages : 4402 Age : 51 Date d'inscription : 19/12/2006
Sujet: Re: Nouvelles Saxonia de Lange (vues sur Horomundi) Ven 13 Avr 2007, 9:23 pm
Si j'ai bien tout compris ce modéle existe en 2 tailles mais uniquement en auto.J'aime beaucoup ,mais mon coeur penche toujours pour la L 1.Il faut quand même avouer qu'il n'y a pas grand chose à jeter chez eux.
