| ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] | |
+282Alxz sedrikget gnome-rhone tactic! Matchoum Fanou88 Nanouch maniaclik adriano40180 lisek21 Loicb17 Jop82 justin33 jc971 gilles42 LeRussePiedNoir golanef LUTEC'S reghiu FDB Malax PHILMAQ Le Doc duke64 tooling Bisontin Tristan-led Airsky anas0102 Phocee13 Syska moughlis Jeff Costello BAAAM pilàlheure pierrot2909 xylotuol MATTP_2697 Indice51coinring Heodrene myrica litobrit Benjpie lechneric QuentinP lincruste Antho056 zcjaais dodginaldo savonette55 pat2007 maxxatak ladelbok OJP Sonyc LaurentVicariot jce12 Kreene19766 YoungWatcher Johannaa N1T5UGU4 TheSilverFox ZEBRAZOMA Nicooooo dmarcos Heero Ludo888 matthieu.lpz ostiefortwo athom9 scialabriccu calimero50fr JLT-78 Fournier antoniocanavesio FABREGOU couscous garbit mikado93 foulane miccoh guney AL1038 EamonnTheGreat CYG armek Maysonave dabu sjf gilles.g livaille Tele 52' TTP timdorez spirou - Hippolyte - P@tek jm38 melvin81000 Trum fuzz Clodalin totof_man Ed the Grocer reloaded rikibri spitrouge henrigermain pecoste Gregos gousset-adrien MisterP invitro59 jasposiris lioreef Hawk julmien micropat H. JulienB123 eric . richard3 TheryC manumag57 zigzag84 girondin Fvintage romain Stephnico -fabien- aureman flloba clyp Callaghan eric 44 Bertrand dnanlor Raph23 HARDOSINFO dasense LeMoi blowtorch aar Jerichobleu Barnabe Fresco eri231 plibou Masterboy13 schpop Trantor caput Bernard Hoche avatar37 frederic070578 DJ67 WG92130 Paco1664 john_29 radiomir komi Ganesh The Dude 37 issais Numist colectorboy MrTheTerminal cchris irazida eric0600 Xiuhtecuhtli fakroun Oh_mega laz97170 nyjzone Mastermold eric999 machinchouettetrucbidule leopoldch JuParis08 shim dathieumaou Neoseb mc35 TibbP Popopski ed2007 numero27 Jodark watchmaster lhom125 franck 29 waingro hitmanflo Mrpicmath36 franck272 Chonum claude13 leprofesseur brunod osswald James77 roi.de.trefle Monk_er HugOmegaSMP quinnybear Milou missa03 caesar diver montre61 xav34 ninolitaliano vaa lemarensin willbur cedthe Arno isosta Paulo11 TheDude fanf91 landeron DAUPHIN 75 Laurent@57 Blancpain1901 Hypnos tu-fan cali41 jean-luc M ALBAN JEAN CLAUDE carrera45 toiche PAPIN1012 padre Servius Biglolle SK007 Jjmart sabreclair hdonf raynew sergio22 gael69 tomys mr bean gwadaman23 Philippe-ch gllobra noxe Polomix batilou Bernard wilfried henry95 wazalaw karamazov stephane28 Jujukoll25 Clemfa mercurio tallard25 Daniel. LeSeb milwatch keroland ChP schaefer jrm75012 michel shoulderblack compas regalis wartaf spow kelorkilé sti26 SILV Wolfy tonado fab7 joshua07g moumoune31 capitaine44 Xaipe 286 participants |
HARDOSINFO Membre Actif
Nombre de messages : 80 Localisation : BESANCON Date d'inscription : 03/08/2017
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Jeu 10 Aoû 2017 - 14:49 | |
| Devant le grand succès que j'ai sur ce forum, j'ose vous questionner reconnaissant l'immense savoir de tous sur tous les sujets.. Il y a quelques temps, j'ai acheté à "vil prix" sur un vide grenier, une TISSOT "1853 TOUCH Expert T013420A en panne.. car trop cher de réparations prévisibles. Elle a subi les outrages d'un bricoleur.( pas la bonne pile, trop épaisse, massacre du circuit, et pas les bonnes vis de boitier) Cela fait beaucoup alors je l'ai mise de côté en attendant.. Aujourd'hui j'ose poser les questions sur cette magnifique bête? J'ai réussi à rétablir les contacts avec une pile adaptée et elle est repartie.. le tactile aussi. On voit bien que le circuit a été démonté (voir l'état des têtes de vis) et devrait être changé. Peut- on trouver ce circuit ?? chez TISSOT? ou passer par un réparateur? et à quel prix? Et si je peux pas tout changer le circuit, Il manque un petit ressort.et plusieurs sont tordus sur ce circuit.(voir photo) Peut t-on ne changer que un ou tous les petits ressorts? Est-ce la cause pour laquelle elle ne sonne plus..? Je me perds dans toutes les fonctions à régler et ne trouve pas le mode d'emploi exact ou service manuel pour cette TOUCH Expert T013420A. Pourriez vous me les communiquer par mel " robert lazert@free.fr " Grand merci d'avance. |
| Sujet: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Jeu 10 Aoû 2017 - 16:07 | |
| Bonjour, Ne comptes pas sur moi pour te donner des conseils , même les "moins-avisés" pour des interventions sur les "quartz" ! Je suis nul !! Par contre , concernant ta question sur les "petits ressorts" , il y a de très fortes chances pour que ce soit eux les responsables de ta sonnerie défaillante ... j'ai eu semblable problème sur une "Casio" Pour remplacer les manquants ou les défectueux , et , ne pas avoir à les "commander" .... : Un truc ! Soit tu sacrifies une anse à pompe , soit un anneau ressort bon marché (question de dimension) Tu récupères le ressort , en l'étirant si besoin est .... Cela "avait" marché pour moi ! Cordialement bernard |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Jeu 10 Aoû 2017 - 16:38 | |
| Merci beaucoup Bernard pour ta bonne idée .. je vais essayer de trouver une anse à pompe , soit un anneau ressort sur des attaches de bijoux. Je ne t'ennuierai pas avec des quartz c'est promis.. j'attends avec impatience d'avoir le droit d'utiliser la MP dès mes 50 posts. Je t'appellerai en direct pour te donner le résultat. très cordialement Robert |
Nombre de messages : 1399 Age : 85 Localisation : sud-ouest = Landes Date d'inscription : 26/11/2012
| Sujet: petits ressort de contact avec la pastille piézo électrique Ven 11 Aoû 2017 - 10:48 | |
| Salut . Oui la sonnerie marchera si le ressort entre en contact avec la pastille pièzo électrique . 1ressort touche la pastille et le 2eme la partie métalique du fond du boitier .pour le reste (les fonctions )tu trouveras tout seul . (il faut des ressorts pas trop raides (assez souples) Bon travail |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Ven 11 Aoû 2017 - 11:24 | |
| Merci pour ta réponse éclairée Je cherche les ressorts et je les change.. |
Nombre de messages : 4277 Date d'inscription : 06/05/2005
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Ven 11 Aoû 2017 - 14:37 | |
| Bonjour Je recherche une bascule de remontoir pour un calibre Seiko 4502 ou un mouvement complet. Merci |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Ven 11 Aoû 2017 - 14:58 | |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Ven 11 Aoû 2017 - 19:21 | |
| Merci à tous!! Que ferais je sans vous?? |
eric 44 Nouveau
Nombre de messages : 10 Date d'inscription : 20/01/2016
| Sujet: tige remontoir zenith Mer 16 Aoû 2017 - 11:49 | |
| bonjour, je recherche une tige de remontoir zenith pour calibre 126-6 merci
contact eric(.)berthet(2)@free.fr supprimer les parenthèses . |
Callaghan Puits de connaissances
Nombre de messages : 4706 Age : 54 Localisation : Côte ouest Date d'inscription : 20/02/2012
| Sujet: Recherche cadran chrono Seiko 4-901045 TA Jeu 17 Aoû 2017 - 20:28 | |
| Bonjour, Je suis à la recherche d'un cadran pour ma Citizen ref : 4-901045 TA. Y'a t'il comme pour d'autres marques un ou des sites qui pourraient fournir ce type de pièce ? D'avance merci |
carrera45 Permanent passionné
Nombre de messages : 2136 Age : 54 Localisation : nantes Date d'inscription : 05/12/2009
| Sujet: endlinks bracelet Yema superman Ven 18 Aoû 2017 - 20:50 | |
| bonsoir les amis on me propose un bracelet de yema superman mais sans endlinks, sont ils facile à trouver? auriez vous un bon plan ? ma 241117 serait contente de retrouver son bracelet d'origine merci |
clyp Membre très actif
Nombre de messages : 219 Localisation : En Gaume Date d'inscription : 27/04/2014
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 19 Aoû 2017 - 12:53 | |
| Bonjour, Je suis en train de nettoyer une Longines 13-15 V (ou 4LLV). C'est pas bien grand : 5.75 x 6.75''' d'où mon problème. je viens de la remonter, mais impossible de retrouver les ressorts-lyres des incablocs du balancier, coté pont ET coté platine Pour dire plus simplement : je les ai perdus Je suis donc à la recherche de ces 2 lyres ou compatible. Un grand merci d'avance. Clyp |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 19 Aoû 2017 - 13:20 | |
| ah ben oui j'ai oublié : voici les ref. incabloc : 270.03 et les ébauches équipées de 270.03 : FHF 57-21 , 59-21, 66 ; FEF 6640, 6650 ; Peseux 7000, 7010, 7016, 7020, 7024, 7030, 7034 Merci. Clyp. |
| Sujet: ressort incabloc Sam 19 Aoû 2017 - 15:07 | |
| Je pense que cela doit ce trouver assez facilement cela doit êtres les mèmes que sur tous les modéles de montre dame calibre 5 1/2 ou 6 3/4 (As 1012 ,FE45 etc) bonne chance |
Nombre de messages : 9719 Age : 64 Localisation : Isère Date d'inscription : 14/03/2009
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 19 Aoû 2017 - 17:29 | |
| Bonjour, je cherche une came de commande chrono pour un calibre Heuer 11 (ou 11.1 / 12 / 14 / 15 / Valjoux 7740) operating lever ref. 8139 merci Isosta |
michel Pilier du forum
Nombre de messages : 1962 Localisation : la plus belle vallée du monde Date d'inscription : 09/05/2005
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 19 Aoû 2017 - 18:48 | |
| - isosta a écrit:
- Bonjour,
merci
Isosta C'est ballot , toi le grand gourou du vintage tu dois avoir une solution : soudure , super glu ...........j'en passe et des meilleurs Ebay LBC Nos amis les anglais |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 19 Aoû 2017 - 22:27 | |
| Salut Michel, Rien sur la baie, rien chez Cousins, rien chez les spécialistes Heuer and Co. pour l'instant c'est "Gourou coucou Paloma" Alors si dans ta grande bonté... Isosta |
Milou Membre référent
Nombre de messages : 5196 Age : 71 Localisation : 68 Date d'inscription : 30/01/2011
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Aoû 2017 - 8:01 | |
| - isosta a écrit:
- Bonjour,
merci
Isosta Bonjour Si jamais (à défaut de pouvoir trouver la pièce) tu devais la confectionner toi-même, ce serait sympa de poster les détails du mode opératoire. J'en ai une à faire qui me semble plus ch..te à faire et j'aimerais bien savoir le faire. Merci d'avance milou |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Aoû 2017 - 9:14 | |
| Pas la en ce moment (vacances jusqu'a mi septembre ) mais cela doit trainer dans une des boites jaune ; autrement tu as la solution de notre ami Milou |
flloba Nouveau
Nombre de messages : 7 Date d'inscription : 14/06/2017
| Sujet: pieces rechange 7005 8020 Dim 20 Aoû 2017 - 10:58 | |
| bonjour a tous. j'ai reussi a refaire marche une seiko 7005 8020 et maintenant je cherche le verre ainsi que le deux joints d'etanchaité. pourriez-vous mindiquer le meilleur lieu pour chercher? et si vous avez qqs indications pour bien nettoyer le boitier, il est un peu rouillé. merci a tous. ptit photo |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Aoû 2017 - 12:41 | |
| Pour mes seiko je trouve sur cousinsUK.com.
Clyp |
flloba Nouveau
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Aoû 2017 - 18:51 | |
| trouves chez cousins les pieces que je pense vont faire l'affaire... merci Clyp pour lindication. |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Aoû 2017 - 20:46 | |
| - lemarensin a écrit:
- Je pense que cela doit ce trouver assez facilement cela doit êtres les mèmes que sur tous les modéles de montre dame calibre 5 1/2 ou 6 3/4 (As 1012 ,FE45 etc) bonne chance
Ben non, malheureusement, je pense que le 270.03 n'équipe que les ébauches que j'ai citées : FHF, FEF et Peseux... mais je n'ai pas d'épaves. Exemple : le AS 1012 embarque un 170.03. Donc, je cherche toujours 2 lyres incabloc 270.03.... Merci. Clyp |
aureman Membre Actif
Nombre de messages : 57 Date d'inscription : 25/06/2011
| Sujet: [Cherche] ETA 2824-2 HS pour pieces Sam 26 Aoû 2017 - 15:10 | |
Suite accident de plongée sur mon Oris diver qui est bien attaquée par la corrosion, je recherche un ETA 2824-2 pour en récupérer des pièces. Je recherche également un disque de date fond noir imprimé blanc 6H. C'est une montre sentimentale toute aide, pour me diriger vers des revendeurs de pièces, est bienvenue.
Merci |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 26 Aoû 2017 - 15:12 | |
Merci |
