ZEN Rang: Administrateur
| Sujet: La mode des oranges pressées Jeu 09 Aoû 2007, 19:33 | |
| Le modèle s'appelle "Oceanic" et est présenté par Thomas Gref watches pour 925 $ - Citation :
- The Oceanic is an impressive 300 meter dive watch with a unique style. The stainless steel case measures 42mm in diameter and is 13mm thick.
The unidirectional bezel is made from solid stainless steel with the numbers and markers permanently etched into the surface.
The top-quality bracelet features solid links, solid endpieces (20mm), and a foldover clasp. The bracelet is adjusted using screw links (not pins).
Both top and display back crystals are sapphire.
The Oceanic is available in many different options. In total, five dials will be available, all of which use Superluminova. The 'arabic' dial is available in black, blue, and dark red. This 'arabic' dial fairly complex, because it is made from 14 separate components (the base, 12 applied hour markers, and the white applied ring for the minute track). The 'Geo" dial is available in black and orange.
Two casebacks are available, either the solid or display back . Each watch is delivered in a lacquered hardwood single-watch box. http://mywatchmaker.net/ThomasGrefwatchesDH.htm _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
Albouk Membre Hyper actif
Nombre de messages : 512 Date d'inscription : 25/06/2007
| Sujet: Re: La mode des oranges pressées Jeu 09 Aoû 2007, 21:26 | |
| Lisible oui les montres oranges ont cet avantage mais elles sont peu portable hors plongée sauf si on garde les cheveux longs et la chemise à fleurs. |
