| [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] | |
+271Mira713 patxi Clouet Papy71 Jango16 Cogito Dam74 Doubleoui Nitneuq MisterG TarHeuer Ludo888 AnthonyBZH guizmo114 Arnaud.A scarroy Jonathan11 nuhl choice ptitnono gael69 hitmanflo tytyblack WatchMeNew nicolasB56 Diudce stiglitz fifo jc22200 CharleyS Paulo11 patrick4859 egareg prestig Ikks alexandre92 Bombiche cuss bo_cru fakroun Jjmart slogann gttac playgucci1 WTWAEL75 Jaynnibal chrupkaksi VAINVAIN7 caput charleyboy franzz albator8888 Baptiste P Fgallet marocain007 stefblac ZEN olibrador chevaliermarco tieralan vava2560 Gylfe paflechien33 depuis1899 broncos fixo92 lebaron1955 Naviluminor romuald21 Tchegeun nicomac floch34 omegakdb droo74 EricB49 Ristretto75 Roro8811 wphantomfr JesseB Matbred xilef Cedric92 Radondin50 LS89 pagode Hermes2000 Skele Bretongb BRUNET JEAN-LOUIS jm13005 Rebib Matt0000 Denis514 bakache2k Cinya jacobus84 Chataigne MaitreRobinton Ash3 TonyK Chirouille LhenCoring jb Tomi fred-le-cousin abdelaboo L'ecureuil ben71210 Raimé Firo61 M3451 jmbgrasse uwsearch seb.tag yapalfeu ploprof fredperry63 john_29 MaxP flyingwords Edd BNJ* _DAVID_ Jackerz rep30 Eric67 alexandrehlt renaud.soler bertrand07 achille-best bob56 Tire-Comédon Auffret-Cariou IOBAF DjaK Adrien29bzh clweb shoulderblack alien411 NiceCoasT haubert gogomarteau Nicocotier69 stef06100 Bertrand ceventy Tiramisu boblaiponje TomSilver drikess Mister N flazz roi.de.trefle Zouzou77 Paulo Dulac Walterlb13 blaids museau xamlam Julien_C_ Relaxman Petit Ktac Mr smoth Fantomas gileto heisenbeberg Rithoun SILV hommemega ydde tinw bamboub FURET stephane63 mickael1210 batilou Bernard amey hontoir michel JEANITOR chicfrancky46 flying-fox frederic070578 strongbow abibas Olivier1975 Pierre Chass lalsacien reversing2002 Fitzgerald. joker06 sabeldom MisterP Unlimited jerem72 AdadaD Tom74940 pilàlheure totof_man isosta Kristjan Mastermold yaumig orangivap valaisan Pierre-Yves Clm-rbs slavia25 bugs52 Doy1 Arno Balibran breizh385 karamazov Milou abstract2004 devanlordi jrm75012 valyno radiomir willbur Kerangaro Loam64 zlanegho10 regalis adriens BillyToons Piaf mathieu004 patrick40 tonado ed2007 ChP montre61 MiniHorlogier ptibeur_de_lu Hypnos schaefer joshua07g Antjac SK007 LEMURIENDESALPES yannickrous blowtorch fab7 kikiF RonRoyce ft1000mp Bee-man poscafé Blasp gmal benabdel AC2N voxduc25 gasteropode keanu666 Polpulatu NOPI senator franck272 kelorkilé Trighom77 gmail skrinch landeron MaximeG Wolfy Big Muzzy libellule70 grafix132 Xaipe 275 participants |
vava2560 Nouveau
Nombre de messages : 19 Date d'inscription : 23/06/2015
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Sam 19 Déc - 22:44 | |
| bonsoir, merci à vous de votre aide,
grâce à votre première identification, j'ai trouvé en recherchant zaria 1801 sur le net, un mouvement qui semble être une copie de ce zaria: le luch 1801 (russe également), de plus sous le balancier de mon calibre, il y avait un marquage assez spécial et il correspond bien au marquage de luch.
http://watchguy.co.uk/service-luch-701-ladies-watch-calibre-180/
encore merci à vous de votre aide précieuse cdlt, valentin |
Wolfy Puits de connaissances
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 0:48 | |
tieralan Nouveau
Nombre de messages : 4 Date d'inscription : 20/12/2015
| Sujet: Renseignement montre mecanique JOSIL Dim 20 Déc - 13:11 | |
| Bonjour a tous, Voila j'ai repérée une ancienne montre de marque Josil sur Ebay et j'aurai voulu savoir si l'un d'entre vous pouvez me dire ce qu'il en pense !!!!! Il s'agit d'une montre mécanique squelette avec un mouvement ES 95 SEMAG AV Swiss 17 Jewels Unadjusted. Étant novice en la matière je m'adresse donc a vous !!!
tieralan Nouveau
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 13:17 | |
| Je n'ai malheureusement pas pu vous mettre le lien de celle ci car je suis nouveau membre mais si vous tapez Josil sur le site vous tomberez dessus. D'avance merci; |
Nombre de messages : 2036 Age : 58 Localisation : Luxeuil les Bains (70) Date d'inscription : 30/05/2012
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 15:40 | |
| Vu! Mouvement correct, mais... Il manque une vis de maintient du pont principal (seconde photo en haut à gauche de la tige de remontoir), et le placage du boitier semble passablement usé (peut-être simplement in problème de reflet sur les photos) Demandes des photos supplémentaires. Bracelet à barrettes spéciales pour changement de bracelet rapide |
tieralan Nouveau
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 15:56 | |
| Voici une photo " /> |
tieralan Nouveau
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 16:05 | |
| Merci libellule70 pour ta réponse
Je trouvais cette montre très joli et j'aimerais un modèle squelette avec un bon mécanisme. Pense tu que l'on puisse remplacer cette vis et éventuellement trouver ce mécanisme ? |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Dim 20 Déc - 17:09 | |
| Pour la vis manquante, c'est trouvable, sans problème Il faut juste dévisser l'autre vis du pont et prendre ses mesures. Après, tu trouveras ton bonheur sur quelques cadavres de brocantes |
schaefer Passionné de référence
Nombre de messages : 3329 Age : 67 Localisation : auvergne Date d'inscription : 16/11/2014
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Lun 21 Déc - 14:32 | |
| - schaefer a écrit:
- Bonsoir,après des recherches, j'ai trouvé le nom qui serais Emile Juillard ,mais rien trouvé sur le mouvement.Merci de m'avoir lu.bonne soirée.
Bonjour,reçu ce midi d'Italie pour compléter l'une ou l'autre,pas la même marque mais presque le même mouvement,une Many si quelqu'un a des informations je suis preneur,et un EJ46 comme la Bulla. Celui de droite est le nouveau.Merci |
ed2007 Pilier du forum
Nombre de messages : 1533 Localisation : SVO Date d'inscription : 10/02/2006
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Lun 21 Déc - 22:14 | |
| Grosse fatigue Quelqu'un pour me rafraichir la mémoire sur l'origine de ce mouvement ?! Merci pour votre aide ! |
chevaliermarco Membre Actif
Nombre de messages : 79 Date d'inscription : 03/09/2014
| Sujet: Montre CORDA > a déplacer Lun 21 Déc - 23:34 | |
| Bonjour à tous ! Je viens de récupérer le chrono de mon grand-père, mais impossible de trouver des info sur cette montre. Il s'agit de la marque CORDA, visiblement des années 60, swiss made, waterproof et anti-magnetic. Ce qui est fou c'est qu'après qq dizaines d'années sans fonctionner, je l'ai remontée et zou! elle est repartit comme en si de rien n'était et après 36h de fonctionnement elle tient toujours l'heure (et je ne l'ai toujours pas remontée) :-) Donc un immense merci à quiconque aurait des infos à partager sur cette mystérieuse marque ! Marco EDIT : me suis gouré en envoyant mon post, pourriez-vous le déplacer dans la bonne section ? : [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Merci les gentils modos ! |
grafix132 Membre très actif
Nombre de messages : 158 Age : 40 Date d'inscription : 11/03/2015
| Sujet: aide et avis montre de plongée ancienne Mar 22 Déc - 12:46 | |
| Bonjour à tous, J'aimerais des infos sur une jolie montre de plongée Tylex, on dirait une "super compressor" mais il parait qu'il y a beaucoup de fausse montre dans ce style . pour info elle est toute acier Je vous joint 3 photos merci pour vos avis [img] [/img] [img] [/img] [img] [/img] |
hontoir Animateur Chevronné
Nombre de messages : 1449 Age : 53 Localisation : Village prés de lille Date d'inscription : 17/02/2008
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mar 22 Déc - 14:18 | |
| oui oui elle est fausse, je te donne mon adresse pour l'envoi.... Je plaisante of course, belle et authentique tocante!!! |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mar 22 Déc - 14:48 | |
| Bonjour,elle est vraiment superbe,quelle mouvement? eta 2472 comme la mienne ? Pas la même marque. |
| Sujet: re Mar 22 Déc - 16:01 | |
| bonjour, oui il me semble ( à confirmer) |
Milou Membre référent
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 5:31 | |
| Très belle montre et mouvement tout aussi beau! Pourquoi le numéro a-t-il été gravé d'une manière aussi élégante? Était-ce courant à cette époque? Merci amicalement, milou |
NOPI Membre Actif
Nombre de messages : 108 Age : 51 Localisation : dpt 91 Date d'inscription : 01/09/2014
| Sujet: Identification modèle Baume & Mercier quartz Mer 23 Déc - 9:04 | |
| Bonjour, Je souhaiterais connaître le nom (ou l'identification) de ce modèle Baume et Mercier quartz (BM 7425) : Il doit s'agit s'agir d'un modèle des années 90. Merci d'avance pour vos infos. |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 10:36 | |
| - Milou a écrit:
- Très belle montre et mouvement tout aussi beau! Pourquoi le numéro a-t-il été gravé d'une manière aussi élégante? Était-ce courant à cette époque?
Merci amicalement, milou Tu parles de la mienne ? Si oui, il s'agit d'un chronomètre avec bulletin de l'Observatoire de Besançon et poinçon "tête de vipère" sur la platine. Cela explique peut-être une attention particulière et une finition certaine... |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 10:44 | |
Si oui, il s'agit d'un chronomètre avec bulletin de l'Observatoire de Besançon et poinçon "tête de vipère" sur la platine. Cela explique peut-être une attention particulière et une finition certaine... Oui Ed c'est bien de la tienne que je parlais. Je comprends mieux maintenant pourquoi elle a été finie de la sorte. Merci milou |
olibrador Nouveau
Nombre de messages : 4 Age : 63 Localisation : 76 Date d'inscription : 23/12/2015
| Sujet: CARILLON Mer 23 Déc - 13:53 | |
| Bonjour à toutes et tous Je possède un carillon marqué véritable Westminster (1958) et en dessous il y a Herwo.Quequ 'un connait il ce Herwo. De + le carillon fonctionne trés bien mais ne sonne ni les quarts ni les heures ,quel est le problème ? Merci et bonnes fêtes à tous. Olibrador |
ZEN Rang: Administrateur
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 14:21 | |
| Un carillon silencieux est une pendule ... _________________ Contraria contrariis curantur. (Les contraires se guérissent par les contraires).
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 14:54 | |
| - olibrador a écrit:
- Bonjour à toutes et tous
Olibrador Les ressorts de la sonnerie des quarts et des heures sont-ils complètement "tendus". Si oui les mécanismes des 2 sonneries sont certainement encrassés peut-être même que les sièges des axes ont subi un dommage. Des photos pourraient mettre en évidence les problèmes. |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 14:55 | |
| si il est marqué véritable Westminster c'est qu'il sonne: ouvre le: tu as généralement un système avec deux cordelettes de chaque coté pour empêcher de sonner. Les deux cordelettes sont accrochées sur des crochets sur l'intérieur des façades. |
| Sujet: Re: [Postez ICI les demandes d'IDENTIFICATION et RENSEIGNEMENTS de vos montres] Mer 23 Déc - 16:02 | |
| - hontoir a écrit:
- si il est marqué véritable Westminster c'est qu'il sonne: ouvre le: tu as généralement un système avec deux cordelettes de chaque coté pour empêcher de sonner. Les deux cordelettes sont accrochées sur des crochets sur l'intérieur des façades.
Oups, je n'ai pas mentionné ça, pensant que c'était évident. |
