| Jusqu’ou avez-vous descendu votre plongeuse ? | |
+249Hockydocky DustB julius357 korai labonneheure Gonzoide Polpulatu Olivier1874 Doconwheels Josh Homme Ced77 vintage76 Sipaliwini cccccccousin doby Garo58 ariake Mister N cedbou83 blowtorch bois56 Facelvega guiguit Comaï Eric l helicopsi OpOw Shinruf willdemerle deninou tagomeginessot Kgérard jm83 ami-call uwsearch al4tis Duality Bender horacio madmic Black_Wolf Oara bond1973 Pierre13 syderco wilburpi SEL13 jodko babky omega67 moulin ft1000mp doudou82 TotoroGMT Ange_Noir ludoducabell Karda lynx25 h2o'clock 7 892emmanuel skydiver Callaghan Manitou Bouss AxelM Mahamaya Zorba06 bichão jgc GEGETOWN ceasar sebribault selfautowach2 Vintage972 guillaume paris StevyB pablito Horloger du Roy voodoo69 FRED2808 ilya kuryakyn _DAVID_ boatpeople wizzard oscar75 RICKO laphroaig007 ah1963 kosmira guinessfrog Hemdale Freediver piwai pmk jaeger92 esteban AdM Vincile bigmamba manu33 hervep christmike cedric79 choukaz tirano66 deepseaking roter.papagei clo kaizer proto*bruno Opeth pevelois bendianons Titofgo AlexDSL verytex urd.bodmod Soulky richardo5 Le Belge niamor LeGarsQuiAimeÇa Cedricmor glouglou fred-tictac jjr74 julien laurent FFREDERIC johan2980 Mandrak Currux dumé lithium YM PATAZAILLE dave bond falky Courbin dustoff Pelf Lalfiste44 phs EtienneBF Thibault83 jeudes Kermitou Nc.87 BlackCat milwatch didier31 vbo PLATYPUS cub PA19 garchi L0r@N Octave OLVACHAR jrm75012 loulou84 TChatenet diversion13 popoff06 Janus DoudouSa chiouahouah toqué opiffe 300M Woodcat Gaël rdretzen atchoum zeppelin bluberry78 loule balibalo Fokker III xav92 evh5150 Kerangaro suoo cheminal67 Manivel francknwatch maveriks pixel14 Liard damattstep stardust2a2b rudy korigan Mr.Tchou EmD breitskin jr78 chrmuller ALMAS13 MK007 henri3108 matrix kjeldor focey brady kiki93 philgasp Fredb hommemega eto.demerzel sanoukfr nermal D.Molina francis28 chougom montresàlafolie seatime philou autrichon gris PP3940 Jecko Olive olivierB robi felix6684 Eric cyrcaete alics cedipro jwhy F.M. titoftwo manta972 Ch-B gece nokia93230 orologio remy b Thelemys olaf grossebaf simonk stiocour neophotographe hieraklion quentinmarcus gautier jean-mariec couscous garbit Mostro900 martiniracing arnaud171275 selfautowash 253 participants |
ALMAS13 Animateur
Nombre de messages : 859 Age : 58 Localisation : Réformé-Longchamps Date d'inscription : 21/09/2008
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Lun 18 Mai 2009, 15:43 | |
| - matrix a écrit:
- quelques questions me taraudent.sur les montres souvent c'est marqué étanche 5bar,10bar,20 etc... mais quelle est l'équivalence en metre.exemple:1bar correspond a combien de metre de profondeur?2 eme question:est ce que la pression pour la meme profondeur est la même en eaux de mer et en eaux douce?
3eme question faut-il faire des pallier de décompression en remontant pour les montre plongeuses?Merci 1bar = 1daN/cm2 largement admis 1kg/cm2 soit une profondeur de 10 (plutot 9,81 pour etre plus pres de la vérité) pour 1 bar donc si la montre est donnée pour 20 bars on doit pouvoir la descendre à 19,62 m (20) théoriquement (hors coefficents de sécurité) |
nermal Puits de connaissances
Nombre de messages : 4049 Age : 65 Localisation : I/c\I Date d'inscription : 01/11/2008
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Lun 18 Mai 2009, 17:58 | |
| - MK007 a écrit:
- La douche ça compte ?
Oui, si c'est ta valeur maxi. Quand j'avais 10 ans environ, mon paternel m'avait offert une montre de plongée "HENAURME" avec la grosse lunette, le cadran bleu, un bracelet Tropic... le panard j'ai foncé vers le seul lieu de test immédiatement disponible : le lavabo... elle y est morte dans les 10 secondes (et pourtant je n'avais pas mis beaucoup d'eau)... Sinon, pas même une petite piscine ? |
MK007 Passionné de référence
Nombre de messages : 3644 Age : 39 Date d'inscription : 18/05/2007
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 17:22 | |
chrmuller Membre très actif
Nombre de messages : 181 Age : 45 Localisation : Genève Date d'inscription : 14/11/2007
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 19:36 | |
| - ALMAS13 a écrit:
1bar = 1daN/cm2 largement admis 1kg/cm2 soit une profondeur de 10 (plutot 9,81 pour etre plus pres de la vérité) pour 1 bar donc si la montre est donnée pour 20 bars on doit pouvoir la descendre à 19,62 m (20) théoriquement (hors coefficents de sécurité) J'ai pas suivi, ou il manque un facteur 10 ? 20 bars = ~200m, non ? Question à la con : la pression à -10m est le double qu'en surface, donc 2 bars, ou je dis des bêtises ? Donc, si je poursuis mon raisonnement, on a 3 bars à 20m (et non 30), 5 à -40, 10 à -90... Ou je suis totalement à côté de la plaque ??? |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 19:53 | |
| - MK007 a écrit:
- Tu as une photo par hasard de cette HENAURME (dans le cas où tu l'aurais gardé.). En tout cas, son étanchéité devait être ENORME!! Bon, ok je sors.
Tu peux rester, et tu as du pot, je viens de remettre les paluches sur mes protos aujourd'hui : La HENAURME est celle de gauche... je l'avais gardée puis bricolée en mettant un quartz/LCD inside que j'ai changé une fois... avec une magnifique peinture perso de la lunette (vers mes 11 ans)... la dernière version est de 1982 bien entendu (proto laissé dasn un tiroir et pile coulée)... après j'ai cassé le verre côté remontoir (il est fendu dans l'épaisseur). Le pire, c'est que jusqu'à la destruction du verre, le bazar fonctionnait !!! Et pas seulement sous la douche, l'engin avait passé plusieurs fois les 30 mètres... A droite mon magnifique compas emprunté à un porte-clefs (que j'avais en double, non mais, je n'allais-pas sacrifier une de mes pièces les plus rares de ma collection de porte-clefs ). Me font rire les Paneristi j'avais déjà le kit MAS quand j'avais 11 ans et je jouais avec les maïale sommozatori dans ma baignoire (d'où l'utilité de la montre ) Sur demande spéciale, je peux livrer des séries limitées personnalisées P.S. détail technique secret... chut... les couronnes de remontoir avaient été bloquées au chewing-gum bien entendu... (Hollywood menthe)... chut... |
jr78 Membre Actif
Nombre de messages : 100 Date d'inscription : 18/05/2007
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 19:58 | |
| - ALMAS13 a écrit:
1bar = 1daN/cm2 largement admis 1kg/cm2 soit une profondeur de 10 (plutot 9,81 pour etre plus pres de la vérité) pour 1 bar donc si la montre est donnée pour 20 bars on doit pouvoir la descendre à 19,62 m (20) théoriquement (hors coefficents de sécurité) Sorry, pour 20 bars, 20 x 10m = 200 m... (à la conversion 9.81 près...) |
jr78 Membre Actif
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 20:00 | |
Question à la con : la pression à -10m est le double qu'en surface, donc 2 bars, ou je dis des bêtises ? Donc, si je poursuis mon raisonnement, on a 3 bars à 20m (et non 30), 5 à -40, 10 à -90... Ou je suis totalement à côté de la plaque ??? Exact... et pour le "bar" de l'atmosphère, on peut supposer qu'à l'intérieur d'une montre "normale", il y a de l'air à peu près à la pression atmosphérique, donc équipression au niveau de la mer. |
matrix Membre Actif
Nombre de messages : 102 Date d'inscription : 04/01/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 20:08 | |
| merci pour vos réponses.En gros ma 6R20 seiko est étanche 100metre.Pas mal pour une montre non plongeuse! |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mar 19 Mai 2009, 22:28 | |
P.S. détail technique secret... chut... les couronnes de remontoir avaient été bloquées au chewing-gum bien entendu... (Hollywood menthe)... chut... Bonsoir Nermal « Nôtre »ami en avait bien raison de vos créativités (chewing-gum)… |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mer 20 Mai 2009, 08:19 | |
Question à la con : la pression à -10m est le double qu'en surface, donc 2 bars, ou je dis des bêtises ? Donc, si je poursuis mon raisonnement, on a 3 bars à 20m (et non 30), 5 à -40, 10 à -90... Ou je suis totalement à côté de la plaque ??? Exact... et pour le "bar" de l'atmosphère, on peut supposer qu'à l'intérieur d'une montre "normale", il y a de l'air à peu près à la pression atmosphérique, donc équipression au niveau de la mer. OK, merci ! J'avais pas pensé à l'équilibre de pression au niveau zéro... Logique... Donc, si une montre supporte 1 bar, c'est réellement à -10m (puisqu'au niveau de la mer, il y a équipression, donc elle subit un différentiel de pression de 0)... |
breitskin Membre très actif
Nombre de messages : 202 Age : 50 Localisation : Savoie Date d'inscription : 09/04/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mer 20 Mai 2009, 15:28 | |
| Bonjour à tous ,
-15 m. avec ma seiko deiver 200 il ya de cela une semaine, en vacances et en initiation plongée à l'ile Maurice. |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mer 20 Mai 2009, 16:38 | |
| Merci Nermal pour toutes ces précisions. Tu es sacrément plus bricoleur que moi. Toutes montres qui m'ont lâché quand j'étais petit, ont terminé par un classement vertical. Et d'ailleurs, je n'ai jamais testé les grandes profondeurs mais j'espère un jour avec mes SM.
Merci pour la photo, je ne connaissais pas cette marque. C'est français ? |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Mer 20 Mai 2009, 19:46 | |
| - MK007 a écrit:
- Merci Nermal pour toutes ces précisions. Tu es sacrément plus bricoleur que moi. Toutes montres qui m'ont lâché quand j'étais petit, ont terminé par un classement vertical. Et d'ailleurs, je n'ai jamais testé les grandes profondeurs mais j'espère un jour avec mes SM.
Merci pour la photo, je ne connaissais pas cette marque. C'est français ? Non... c'est comme moi : - 1/4 Corse - 1/4 Français - 1/4 Italien - 1/4 Suisse RG ce sont mes initiales et le reste mon invention avec des lettres Decadry. Le tout est comme moi : bien secoué |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Sam 23 Mai 2009, 17:23 | |
| [/quote] - 1/4 Corse [/quote] J'espère que l'aiguille des secondes ne tourne pas au ralenti! OK, je . |
D.Molina Permanent passionné
Nombre de messages : 2324 Localisation : Sandhaas Date d'inscription : 05/05/2005
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 24 Mai 2009, 14:23 | |
EmD Membre très actif
Nombre de messages : 183 Localisation : Levallois-Perret Date d'inscription : 27/01/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 24 Mai 2009, 14:33 | |
| Environ 12 mètres (omega seemaster) |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 24 Mai 2009, 14:34 | |
| - Citation :
- Jusqu’ou avez-vous descendu votre plongeuse ?
Profond, très profond... H3 |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 24 Mai 2009, 16:25 | |
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 24 Mai 2009, 19:24 | |
Mr.Tchou Nouveau
Nombre de messages : 3 Date d'inscription : 31/05/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Dim 31 Mai 2009, 16:03 | |
| Mon aquachrono : 25m ma traser : 45m ma seiko Diver's 10-12m |
korigan Pilier du forum
Nombre de messages : 1675 Localisation : Entre pins et océan :-) Date d'inscription : 30/09/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Jeu 03 Juin 2010, 16:34 | |
| -37 ou 38 m je sais plus trop pour ma diver 200 seiko d'un côté et la Casio - SPF-60-1AVER de l'autre. A noter pour cette dernière que le profondimètre s'est mis en stand by sous les 30 m, sa profondeure max théorique qui s'est avéré vrai en pratique mais qui a repris toute sa fonctionnalité une fois ce seuil repassé |
rudy Animateur Chevronné
Nombre de messages : 1293 Age : 57 Localisation : Belgique (Seraing) Date d'inscription : 25/12/2006
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Jeu 03 Juin 2010, 19:30 | |
| avec ma citizen promaster - 82m sub date 16610 -60m bonnes bulles |
stardust2a2b Membre super actif
Nombre de messages : 439 Age : 49 Localisation : Ajaccio Date d'inscription : 16/10/2007
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Jeu 03 Juin 2010, 19:51 | |
| 3 mètres |
damattstep Membre Hyper actif
Nombre de messages : 525 Date d'inscription : 05/06/2009
| Sujet: Re: Jusqu’ou avez-vous descendu votre plongeuse ? Jeu 03 Juin 2010, 19:52 | |
P.S. détail technique secret... chut... les couronnes de remontoir avaient été bloquées au chewing-gum bien entendu... (Hollywood menthe)... chut... Moi qui cherchais un horloger......... |
