| ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] | |
+265jimpqfly stickybaby zuppa PhilPARIS Lepitao Yves13011 Thibault0801 ChrisC75 GEEKOFWATCHES tonado Omegines La Fruge microno GournierO rhonyx Mrpicmath36 thl Celsius tgolf59 xanaxabi64 Liviu biwann NaKKdry Francois46 Milannimes Thierry Sanchez Fabouch2979 DJ67 Double-Bou YopSolo Kohmak Flobert38300 lithium 3ug3n Bubba giraltgeorges Chappaz cigalon fonzie Ganlanshu doccky Казимир Yann Riquier Proktor TheFutureIsNow Tristan-led gilles42 thibault_ctn Leumass96 Nicodas ya2n dan.bar76 De Guerre Almagnifico Cadrature zaox Petitpied perenowell JohnRaz jmaz Mathieu580 Mounir mohabon95 billou JeepAero py3.14 Fr4nc01s Germanicus_ PhJ marc-anton Marcouf Bertrand douve.baron Vince34 Rootciv j&b Larri40 AnthonyBZH seba310v6 batilou Ddq92 Beber 55 YoungWatcher L4UR3NT bibi78390 Matoumoiss adriano40180 gonof JustAlfa melvin81000 Patrick VdB eliotrop boris59132 Nicolong hommemega Jeff de France buitonni kanrabat Carpette Mat6494 G&N roi.de.trefle Diom86 zeppelin Flector Ed the Grocer reloaded pol oam westaf monfrayd Saymone montre61 Tony1968 pitboost Tom38230 Antho056 White Bunny iacopino dominique Kerangaro filgood69 DEVAUX jann353 david h. Skad vieillemeca Bluk-Bluk pento57 Vir Frederick1973 landeron hitmanflo Rom1902 davidu91 Flukyluc gycyole charlp3 ThierryD raynew oversea2 Plyma 44 Bouddhe Quentin.NS petitluc38 yangra basile772 vilcoyote17 Vintagemaniac fendrede22 fly back Busdigan Pascal YanKristian CANDEREL l10n3l newsensor SUBTIME regalis Fournier jhc18 ixere peache1 Luka Mmanatane dnanlor LionelMlesmontres marcoleroi Candc674 Jide almanach31 Patrimonio tomys xavhyv rotrocs stephane28 apprentie ankou22 Eurier Lost'N'Drunk tompouce71 frederic070578 tx725 Electro Moped henry95 Noalio Romain5813 mauste Pierre-Yves plibou numero27 jabumaso Marcoux74 brunod mkl Mitch83 hubloter maitre mercurio mentor baratier Vlad le Russe lolobobo pilàlheure matt210192 ZenethaaR Nomadsoul arbigoud Guymo tactic! rav6en schaefer tot076 bamboub dav1703 SK007 hontoir Philippe-ch blowtorch nono007 SkyWeb lucyluky Bisontin Zugues Jjmart MisterP golanef collector83 isosta Gorgu Saunick Deucalione FRLouis Mr Yellow willbur Ludo888 gilles.g pourpette christian l tic68 Arno BAAAM Wolfy satriani33 PierreSpe michel machinchouettetrucbidule sylvav Mister N Hypnos lhom125 kelorkilé Marie37 Markeu simke fab7 milwatch shoulderblack spirou miccoh Airsky calimero50fr lemarensin Solcarnus Tass2909 cartésien desabusé Xaipe 269 participants |
JustAlfa Membre très actif
Nombre de messages : 181 Localisation : Dans le haut Date d'inscription : 28/03/2020
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Sep - 1:32 | |
| Super , merci pour ce lien ? Je ne comprend pas trop les diamètres, quelle est leur unité de mesure ? |
Patrick VdB Nouveau
Nombre de messages : 21 Age : 65 Localisation : Mesvin Date d'inscription : 20/04/2020
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Sep - 1:56 | |
| En 1/10° de mm, donc un diamètre de 300 = 30 mm = 3 cm... Donc, pour vous, ceci devrait être la bonne référence : https://www.servia.be/fr/verre-mineral-100mm/10888-verre-mineral-100mm-mmso-300-9999000094885.html
Mais vérifiez toujours si d'autres références ne seraient pas préférables... Par exemple : https://www.servia.be/fr/verre-normal-bas/18044-verre-normal-bas-nmb-o300-9999000130378.html |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 20 Sep - 2:51 | |
| Comme dit ci dessus par Patrick ceci devrait aller sans problème https://www.servia.be/fr/verre-mineral-100mm/10888-verre-mineral-100mm-mmso-300-9999000094885.html ceci a condition que le passage des aiguilles soit prévu ???? si le verre d'origine est minéral pas de problème si non il faudra un verre bombé pléxi ou autre ( verre collé ou rentre en force avec une presse ???) |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Lun 21 Sep - 5:52 | |
| Merci pour vos réponses. Je vais voir pour commander mon verre Actuellement il s’agit d’un verre plat de 30mm de diamètre sur 1mm d’épaisseur. Je pense que c’est un verre minérale (ou acrylique). Il tient par « force », je met des guillemets car une simple pression avec le pouce permet de le retirer/replacer. |
gonof Nouveau
Nombre de messages : 13 Age : 64 Localisation : paris Date d'inscription : 04/03/2009
| Sujet: aiguilles Rotary Aquaplunge Mer 30 Sep - 2:31 | |
| Bonjour
Je suis à la recherche d'un jeu d'aiguilles ( heures et minutes) pour un Chrono vintage diver Rotary Aquaplunge de 1965 . Il est animé par un valjoux 92 . Je sais qu'il y a eu plusieurs marques s'étant servi du même boitier et je crois savoir qu'il y a eu également plusieurs mouvements .De ce fait, je ne sais pas si les aiguilles sont adaptées au divers calibres. Si quelqu'un sur ce forum a des infos pour trouver les pièces pour ce genre de montre , votre aide sera appréciée .
merci de m'avoir lu |
adriano40180 Membre très actif
Nombre de messages : 176 Age : 33 Localisation : France, Aquitaine. Date d'inscription : 04/11/2018
| Sujet: Trouver joint lunette boîtier Sam 3 Oct - 5:46 | |
| Salut, Je me retrouve avec un petit problème, j'ai démonté la lunette du boitier de ma Seiko pour matifier l'ensemble boîtier, lunette et fond. Le problème c'est que le joint qui maintient la lunette sur le boîtier (très comparable a un joint de verre) c'est agrandi... Impossible donc de remonter la montre . Je voulais savoir où je peux retrouver un joint similaires Le où il vient ce siéger. Merci a vous. |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 3 Oct - 8:25 | |
| Quelqu'un pour confirmer le joint ?
https://justtime.be/fr/i-ring-120-for-130-150mm-glasses/4081-i-gasket-306x298mm.html |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 3 Oct - 20:56 | |
| Quelle est la référence de cette Seiko ?? (gravé sur le fond de boite ) série de 2 fois quatre chiffres,ou lettres |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 3 Oct - 21:00 | |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 4 Oct - 1:57 | |
| Ici sans doute ??
>> https://www.ebay.fr/itm/Bezel-Caseback-Gasket-Set-For-Seiko-SNK355-7S26-01V0/114307845043?hash=item1a9d474bb3:g:7L8AAOSwseJfELTL
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 4 Oct - 6:15 | |
| Ok merci j'ai donc commandé un joint Seiko 8617 8750, comme référence sur votre lien, j'espère que c'est le bon. |
Matoumoiss Nouveau
Nombre de messages : 47 Age : 82 Localisation : Paris Date d'inscription : 07/11/2018
| Sujet: ch pièce LIP Durowé Dim 4 Oct - 19:08 | |
| Bonjour, J'ai une Lip automatique mouvement DUROWE dont l'axe de masse oscillante est HS. Est ce que cela se trouve? D'après mon horloger favori, la pièce convient aux modèles 7420 à 7428. Lui il n'a pas trouvé mais il n'a pas que cela à faire... Je peux toujours l'utiliser en la remontant mais ce n'est pas conforme... Merci (je n'ai rien trouvé sur ebay) Cordialement. |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 4 Oct - 20:45 | |
| Oui cette référence est la bonne pour ce (joint de lunette = gasket for bezel ) 8617-8750 |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 4 Oct - 22:25 | |
| Salut . la piece que tu recherche est l'axe de masse oscillante qui a pour référence 1496 on la trouve sur internet
ICI >>> https://www.ebay.fr/itm/Ricambi-Int-Durowe-7425-ref-1496/202680285320?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160811114148%26meid%3D461e27707da049c081bc158587fc2494%26pid%3D100667%26rk%3D4%26rkt%3D8%26mehot%3Dnone%26sd%3D254500137105%26itm%3D202680285320%26pmt%3D0%26noa%3D1%26pg%3D2334524&_trksid=p2334524.c100667.m2042 |
Antho056 Membre Actif
Nombre de messages : 126 Date d'inscription : 15/02/2018
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 11 Oct - 21:43 | |
| Bonjour à tous, Dans le cadre de la restauration d'un Yema Sous-Marine équipée d'un calibre ETA 2789, je recherche : 1 vis de masse oscillante (la vis centrale qui maintient la masse sur le pont) et potentiellement 1 masse oscillante (en bon état si possible). Autant pour la masse oscillante la baie est garnie, autant pour la vis, je n'arrive pas à mettre la main dessus. D'avance merci, Cordialement, A. |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 11 Oct - 22:27 | |
| Salut Antho056
regarde ci dessous
>> https://speedtimerkollektion.com/shop/product_info.php?manufacturers_id=56&products_id=50453 |
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Dim 11 Oct - 22:30 | |
| - lemarensin a écrit:
- Salut Antho056
regarde ci dessous
>> https://speedtimerkollektion.com/shop/product_info.php?manufacturers_id=56&products_id=50453 Superbe, je ne connaissais pas ce vendeur ! Merci beaucoup. A. |
White Bunny Nouveau
Nombre de messages : 10 Localisation : Île de France Date d'inscription : 06/05/2020
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 17 Oct - 5:05 | |
| Bonjour, J'ai récemment fait l'acquisition d'une petite Oméga femme. Malheureusement, le bracelet est trop petit pour moi. J'ai cherché sur internet avec la référence du bracelet, mais je ne trouve rien. Je souhaiterais acheter des maillons... Voici une photo : Quelqu'un pourrait-il m'aider svp ? Merci |
bibi78390 Nouveau
Nombre de messages : 8 Localisation : yvelines Date d'inscription : 08/04/2016
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 17 Oct - 10:05 | |
| Bonsoir, bonjour; je suis à la recherche d un ressort de barillet de montre à gousset de marque robur avec un mouvement A.S 1063 et quelques informations sur ce mouvement. Merci de votre sollicitude ! |
L4UR3NT Nouveau
Nombre de messages : 19 Date d'inscription : 14/12/2019
| Sujet: Recherche désespérément drageoir Dim 1 Nov - 20:56 | |
| Bonjour, Je suis à la recherche d'un drageoir argent pour un gousset oméga. La tâche me semble quasi impossible alors si quelqu'un connaît un moyen de fixer le verre sur une lunette sans drageoir je suis prenneur. merci d'avance |
G&N Membre référent
Nombre de messages : 5290 Date d'inscription : 04/12/2009
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Lun 2 Nov - 10:16 | |
| Bonsoir à tous, Ce merveilleux chrono Heuer 11.402 mû par un Valjoux 9, a besoin pour une restauration optimale d'un ressort de compteur de minute qui... est carrément introuvable. Quelqu'un aurait-il un tuyau...? Par avance, merci. |
YoungWatcher Membre Actif
Nombre de messages : 72 Age : 25 Localisation : France Date d'inscription : 29/03/2018
| Sujet: Re: ICI vos demandes de recherche de FOURNITURES ET PIECES [Topic Unique] Sam 7 Nov - 2:02 | |
| Bonjour à tous, Je suis à la recherche d’un boîtier pour FE140. J’en ai pas trouvé pour l’instant |
Beber 55 Membre très actif
Nombre de messages : 179 Localisation : Grand est Date d'inscription : 01/05/2020
| Sujet: Please HELP!!! fin de restauration d'un Régulateur! Mar 17 Nov - 3:39 | |
| Bonjour à tous, Depuis plusieurs mois, je suis sur la restauration de cette belle montre régulateur. Elle est entièrement nettoyée et révisée. Malheureusement, un horrible "verre" acrylique défigure cette belle vielle dame . Quelqu'un pourrait il m'aider à trouver un verre dimension 550 pour terminer ce projet? Merci infiniment!! [url=https://servimg.com/view/20212729/68] [/url] |
| Sujet: Please HELP!!! fin de restauration d'une montre Taunus Mar 17 Nov - 3:56 | |
| Rebonjour à tous! Encore un autre projet qui me tient à cœur, cette belle montre Le Taunus, achetée il y a plus d'un an en attente de trouver un balancier. Il y a quelques temps, chose faite! Balancier prélevé sur une carcasse et adapté et ça marche!! Pour terminer le travail il me manque une couronne en forme de boule. Les dimensions de la partie qui reçoit la couronne (désolé je ne connais pas le terme) est: 90 mm externe et 70 mm interne (voir photo) Et il ne s'agit pas d'une couronne vissée (voir photo) Si vous pouviez m'aider à la trouver ou m'indiquer ou la trouver je vous en serais très reconnaissant Merci à tous! |
Ddq92 Nouveau
Nombre de messages : 1 Date d'inscription : 17/11/2020
| Sujet: Remplacement verre sur montre Yema presque vintage (1996) Mar 17 Nov - 6:27 | |
| Bonjour Je possède une montre Yema V 722 YE 525 dont le verre est brisé. J'ai contacté Yema qui m'informe qu'ils n'ont plus de pièces détachées (verre de montre !). Avez-vous une solution à me proposer ? Je tiens à cette montre qui fonctionne parfaitement. Je réside en région parisienne. Merci d'avance. |
